Create Email Error Message
Thread begun 1/24/2011 10:36 am by Dave Buchholz | Last modified 6/16/2011 1:43 pm by Jason Byrnes | 6765 views | 18 replies |
Dave BuchholzBeta Tester
I am seeing this error when trying to edit existing email messages
If you install the latest form builder beta it should correct the problem.
Or if you go to the file referenced you can add code to the line above the error:
var theServerLanguage = "PHP";
We will try to get a dot release to address this issue out soon.
markhaynes75235
Hi Ray and Dave:
I got this error today when I opened the Universal Email Server Behavior in a file on my Windows 7 system. I checked the file path
C:\User\<username>\AppData\Roaming\Adobe\Dreamweaver CS5\en_US\Configuration\Shared\WebAssist\DocumentEncoding.js
and was able to eliminate this problem, but when I went back into the WAUE server behavior I got this error:
At line 391 of file
"C:\Users\Markh\AppData\Roaming\Adobe\Dreamweaver CS5\en_US\Configuration\WebAssist\DocumentEncoding.js":
InspectEmailTags is not defined
I'll see if there's a thread on that error....
enthusiastically,
mark h
markhaynes75235
In my previous post the path did not include the Shared folder. It should be:
C:\Users\<username>\AppData\Roaming\Adobe\Dreamweaver CS5\en_US\Configuration\Shared\WebAssist
I did not find a thread on the InspectEmailTags is not defined error in the forums - Do you know anything about this, Ray?
Thanks!
Jason,
I have come across this issue this morning on a new CS5.5 install
here is an updated copy of the Configuration\Shared\WebAssist\DocumentEncoding.js file that should correct the problem.
Thanks Jason,
I'll let you know if I have any more issues.
No worries Dave.
wbrooks199805
Getting same issue
and my mail is not sending..I have the same screen shot but I need to know the file path for mac dreamweaver5.
I have the newest form builder but using only universal email.
The email was sending when I had my form post to the thank you page but then the info wouldn't post to the database. I put the new fix in for the redirect also that I found on another thread.
I would appreciate some feedback asap.
