HTML Editor 3 with pages created using HTML Editor 2
Thread begun 1/21/2011 7:44 pm by YellowCircleWeb | Last modified 1/24/2011 5:12 pm by neilo | 6972 views | 12 replies |
YellowCircleWeb
Just a quick question - I am working on a site at present where I have created a CMS using HTML Editor 2 - if I upgraded to HTML editor 3 would I simply have to uninstall the HTML editor 2 extension, install the v3 extension and then carry on working?
I don't want to upgrade and then have to re-create all the CMS pages again...?
neilo
From what I can see, the file structure of HTMLEditor3 differs to some extent from HTMLEditor2 and the way that user styles are created and written to file is different too.
If you began applying HTMLEditor3 to your CMS, it would create a new folder (webassist/ckeditor, webassist/kfm) so you would have a whole new set of files. It is likely (though Ray or Jason may correct me) that you would have to reapply your existing bindings to each new HTMLEditor3 instance, and perhaps juggle some paths.
If you have created a CMS using HTMLEditor2, it would be best to continue with that to completion - so you have a finished working version online, and then perhaps you could duplicate your local site and play around a bit with the new version on your local testing server if you then wanted to.
YellowCircleWeb
Thank you for the advice Neilo - much appreciated.
Ray/Jason - could you confirm whether I would need to re-apply the behaviours again, it's a pretty complicated CMS I've created so I really don't want to mess things up. Also, is it possible to have and use both HTML Editor 2 and HTML Editor 3 installed at the same time so I could continue to use v2 for sites I'd already written and use the new version in the future?
neilo
Hi Ian,
Just to say that I applied the new HTMLEditor over a previous version in a CMS on one of my sites (having backed up first!).
All wen't smoothly, (I had to set the Site Settings first) and the bindings all stuck just fine.
The only problem I have at the moment is that it won't recognise the site styles that I had previously set for the styles select list, which is a bit weird, as it has found the 'body' style and applied it OK, and the 'body' style was one of the styles in the site styles stylesheet.
So this means that it has found (and is recognising) my site styles, but clicking the styles select list in the Editor interface produces an entirely empty list. The path to the stylesheet is correct in my update and insert pages. One thing that does happen whenever I make any change to the HTMLEditor code however (when I was checking the stylesheet paths - relative/absolute) is that I get an error message (see image).
Also, the file manager is currently not working, returning an error in the File Browser window:
  alert("MDB2 Error: no such table\nSELECT extension, plugin FROM kfm_plugin_extensions WHERE user_id=1")
Undoubtedly my carelessness, but I have gone over the procedure several times, and can't spot my errors.
OK, tried several more times, and still no site styles. Final result is third image. Error message pops up at most stages.
YellowCircleWeb
Thanks for the update - I too have been having trouble getting my own styles to work in the editor, hopefully webassist mods will be able to shed some light on this issue. Just one other question for you Neilo, do you have the form builder 2 beta installed? I do, though I don't use it. I'm wondering if this may be causing the styles problem?
neilo
Hi Ian,
Yes I do, - as it says somewhere (my brain has frazzled) that if you have FormBuilder2 installed, you have to install the Beta build 023. That was a bit annoying as it shows as version 2.0.0 in the Extension Manage version column. I think I already had it installed, but uninstalled it and reinstalled it again - only then noticing that it still says version 2.0.0.
The Build number is in the access blurb in the bottom panel (assuming it's selected). Minutes turn into hours, and hours into days.
Am having another go with fresh test install of PCMS and then HTMLE3 on another server, largely because I am avoiding some design work that I have a mental block about.
Seems like HTMLE3 almost works. Hope it does, as have recently bought two spare licences for PCMS3, and maintenance likely on various HTMLE 2 installations.
YellowCircleWeb
I'm gonna play about with HTML Editor 3 on one of our dev servers, if I find anything out that may assist you (and others) in relation to the custom styles I'll post it on here.
Update: I've done a bit of digging around in the files and found a directory called 'styles' (located at: webassist/ckeditor/plugins/styles/styles) within HTML Editor. In this directory there is a single JS file called default.js and it's this file that contains the default styles that HTML is displaying - I tested this by adding my own additional style to it and then checking that my style was displayed in the editor and it was. Therefore the problem is a setting somewhere within HTML editor that is either not updating this default.js file with my custom styles from my stylesheet or a setting that is not being changed instructing HTML Editor to use my stylesheet instead of the default.js file.
I cannot get my custom styles to appear in the editor any other way than editing the default.js file by hand, which is obviously not what you want to be doing each time you use an instance on the extension.
neilo
Cheers for that Ian,
I had found that, and also discovered that if you add the styles during the run time of the HTMLEditor3 configuration GUI under the styles tab (you can add individual styles here - but again, one by one - one property at a time) - that the javascript file is replaced with the styles that you enter at that stage.
None of which helps with just loading the styles from the stylesheet. I know that the HTMLEditor has referenced my site stylesheet, because it has adopted the 'body' tag which is defined in that stylesheet.
Mind is too frazzled to think.
Thanks,
neilo
Loading styles from a style sheet to the styles list is not currently supported. They need to be added manually.
Since displayed styles have a label, associated tag, and can be inline css, or come from a class, or just be tag based, it isn't really possible to get all of the necessary information from a style sheet alone.
Willi Schneider
Originally Said By: neilo
Hi Neilo
I've had that error, too. The fix is quite easy:
Use a database admin tool like phpMyAdmin and delete all tables related to the "KFM"-filemanager.
Be sure to make backups of these tables before deleting them, in case something goes wrong.
All the tables have a naming convention like "kfm_something_somthingelse".
Then apply the new "HTML Editor 3" to your form page. Preview your form page in the browser. When using the filemanager for the first time, you will be asked to reload the page to have tha database refreshed. At that point all the necessary "kfm" database tables will be created and everything should now work.
HTH
Willi
