DataAssist Wizard created Insert and Update pages that do not function
Thread begun 1/19/2011 9:08 am by turk361661 | Last modified 1/19/2011 11:26 am by Jason Byrnes | 2059 views | 3 replies |
turk361661
ISSUE: DataAssist Wizard created Insert and Update pages that do not function
I recently installed WADataAssist208.mxp. Before doing so I un-installed the old version.
Icreated a new site. I went through DataAssist wizard.
I opened up my search page in a browser (products_Search.php).
It opened. I filled out the form for my search criteria.
After clicking Search it takes me to my Search Results page. Everything is good up until this point.
I run into an ERROR when I try to insert or update my items.
If I click to Insert an item it takes me to the products_Insert.php page. I fill out the form and then I receive a "NOT FOUND" error:
Error message: The requested URL /Applications/MAMP/htdocs/Dynamic3/products_Detail.php was not found on this server.
A similar error happens when I try to update a page. I can fill out the form on the product_Updat.php page. However after clicking the Update button I receive a "NOT FOUND" error just like the one I received in the example above.
NOTE: Before running the DataAsssist wizard on my site I unistalled my old verision of DataAssist and installed the new release:
WADataAssist208.mxp
Can you please assist with figuring out why the DataAssist wizard is not working for the Insert and Update pages and how to fix the issue?
Thanks for your help,
Danielle
see this thread for details on the problem and a fix:
showthread.php?t=17866
turk361661
overriding original wizard settings
Thanks for the helpful information.
I replaced the file as they suggested and it is working correctly.
One other question:
When I run DataAsisst again for the same page type (e.g. administrative), it adds another form container to the products_update, products_insert, products_search, etc. pages.
When I view the products_Insert Page for example. At the top of the page is the Insert container containing the parameters I initially entered into the Data Assist Wizard the first time. At the bottom of that container form are two buttons, Insert and Cancel.
Underneath those buttons is another container which shows a similar form containing my updated parameters that I entered into Data Assis Wizard the second time.
If I need to re-run data assist wizard to adjust one of my parameters how do I get it to override the first version so that the page only has one container form on it?
thanks,
Danielle
The Data Assist Wizard is not re entrant.
If you need to modify the settings after running the wizard, you will need to modify the individual server behaviors.
you would need to go to the Server behaviors window, Window -> Server Behaviors, and click on the Insert Record or update record behavior in the list to edit it.
