Wizard Error
Thread begun 1/17/2011 9:51 pm by info13749 | Last modified 1/24/2011 1:54 pm by info13749 | 4044 views | 8 replies |
info13749
Wizard Error
Hi All,
Wondering if anyone has experienced an error with the checkout wizard.
I'm getting an error dwscripts fixup selection is not a function - please see attached.
Any solution would be greatfully appreciated
Cheers
Hummm, that's not an error I've ever seen before. Have you tried deleting the Dreamweaver Cache file from the users configuration folder:
If you still have the error, can you provide some additional details:
What is your OS and version of eCart?
info13749
error
Hi Jason,
Thanks for getting back to me, unfortunately I had to delete the Cache file qutie a number of times yesterday.
After experimenting, I found out it fails everytime when applying it to a template in one of my projects, I have been able to get to work a few times when not applying a template.
I'm using windows 7 and cart 5.03, the problem existed in previous versions of the cart wizard, don't know if it was the same error, I never used the wizard much, but I'm now converting all my websites from ASP to PHP.
Previously I've uninstalled all extensions and reinstalled just the ones I need.
Best regards
Norman Young
Can you send a copy of the template so i can try to reproduce the issue.
info13749
Error
Thanks for your assistance, attached is a template and some files that fail everytime
here is an updated copy of the configuration/floaters/WA_eCart_Floater.htm file that should correct the issue.
please copy it over the existing one in your configuration folder at that location, if you need assistance finding the configuration folder, see the common installation issues file:
info13749
Thanks Jason, the patch worked fine.
The only thing I noticed is that after running the wizard the first time, I then deleted the files and went to run it again with different parameters. The wizard failed to start until I closed and re opened Dreamweaver
Cheers
Norman
OK, glad to hear it is working.
I haven't had that happen with the wizard not starting till a rebooting Dreamweaver.
info13749
Hi Jason,
Just to let you know, the wizard still has a few bugs in it.
It fails to add my connection string <?php require_once('Connections/moshptyMySql.php'); ?> in the head and it also removes an include from an editable region and places it the head area
cheers
Norman
