HTML editor not showing
Thread begun 1/13/2011 5:20 pm by Larry321390 | Last modified 2/14/2011 11:24 am by mick358555 | 1904 views | 2 replies |
Larry321390
When I click edit nothing happens. I get a blank space and the editor icons do not show up.
See attached screen shot.
make sure that the entire HTMLEditor folder has been uploaded to the server.
if it is still not working, view source of the edit page and check to see if there are any php errors being reported.
try viewing it in firefox, and check the firefox error console to see if there are any javascript errors reported.
mick358555Beta Tester
Similar Problem - IE9 appears to be culprit
Hi
I too have experienced exactly this type of problem. I have completely reinstalled V2.1.0 from scratch with a new database, different server and still the same problem. Then I remembered I had installed IE9 RC in the last couple of days, seemed to be working fine with Dreamweaver so did not suspect at first. Desperation set in so I tried Chrome and then all of a sudden the editor burst into glorious life. If you experience this, check you're not using IE9 RC
