Menu navigation in separated boxes
Thread begun 1/05/2011 1:47 pm by mhollis382262 | Last modified 1/06/2011 6:27 am by mhollis382262 | 2390 views | 2 replies |
mhollis382262
I would like to have my menu items line up right side by side and CSSMenuWriter is creating blocks that are spaced apart.
I have played around with the plugin and have re-created this menu five times and cannot seem to get the little blocks with the menu text to appear close to one another. Additionally, the drop-down menu items are spaced far apart, too.
You can see the web page here: new/
I have looked at the CSS, trying to edit that. I've re-created the menu five times and each time it gives me this spacing, which is not acceptable. Additionally, Dreamweaver shows the menu as all lining up across the top, while Firefox and Safari show the "blog" menu item as underneath the rest of the menu. I'm trying to get everything on one line and all menu items sticking to each other.
Changes that I make in CSSMenuWriter all look just fine, but once the menu is created, it has this spacing.
the problem is being caused in the general.css file. you have the following:
#outerWrapper #topNavigation ul li {
list-style: none;
display: inline;
padding: 2px 10px 2px 10px;
which is setting a 10px right padding and 10px left padding.
try changing:
padding: 2px 0 2px 0;
the short hand is top left bottom right, so:
is the same as:
padding-top: 2px;
padding-left: 0;
padding-bottom: 2px;
padding-right: 0;
mhollis382262
Problem solved
Jason, that was the issue. I thought that what I had in my stylesheet was overridden by CSS Menu Writer.
Actually, I wonder if I should have any style at all in general.css.
