error messages in testing server
Thread begun 1/03/2011 6:05 am by tom-bissonette400756 | Last modified 1/03/2011 11:48 am by Jason Byrnes | 1382 views | 1 replies |
When I attempt to submit my contact form Created in CSS FormBuilder I get these errors:
Warning: chdir() [function.chdir]: No such file or directory (errno 2) in C:\wamp\www\webassist\email\mailformatting_php.php on line 140
Warning: require(Blank.php) [function.require]: failed to open stream: No such file or directory in C:\wamp\www\webassist\email\mailformatting_php.php on line 142
Fatal error: require() [function.require]: Failed opening required 'Blank.php' (include_path='.;C:\php5\pear') in C:\wamp\www\webassist\email\mailformatting_php.php on line 142
Help!!!
sounds like the site definition is set to use two separate locations for the local files and the testing server files.
make sure that the local files path is the same as the testing server files path so that all of the files will be created in the same place the testing server is looking for them.
