How to modify eCart after Wizard creation
Thread begun 12/16/2010 10:20 am by Steve | Last modified 12/17/2010 7:16 am by Jason Byrnes | 3834 views | 6 replies |
Steve
Hello,
I'm setting up a cart using the latest version 5.0.3 and have a condition where I will need to modify things like Authnet IDs and Shipping. I need modify these "after" the cart is created.
I've already experienced some errors in dropping the cart pages into prior formatted pages so I have a clean set of Wizard generated pages to start.
Is there a way to access the shipping and Gateway values AFTER the cart pages are created?
For instance I need to remove Shipping (UPS) and then add it back later after the client finds his user account details?
Is this possible? Is there a single source config file to search out that has the base parameters that I can toggle on and off?
Does everyone generate simple wizard pages then overlay templates each time you make a significant change to a cart?
Thanks to anyone that can help with this basic info,
Steve
Steve
Disabled shipping in the Cart Control panel but still get an error.
Uploaded eCart1_PHP.php and WA_eCart_Definition_PHP.php after said mod
Error still looks to be trying to use Shipping (with placeholder values)
Error:
Shipping Quote Failed
We're sorry
Invalid Access License number
Is there not a way to disable shipping quotes for testing?
the error is caused because the shipping rate look up behavior is still being triggered.
open the confirm page, and go to the server behaviors window.double click on the UPS shipping rate lookup behavor to edit it.
you will either need to add real values to it, or edit the trigger if statement to an if statement that wont happen, like:
if("" != "") {
Steve
Jason,
That worked perfectly....
Thanks.
Is there any error logging? Reason being I tried a test using a known test Credit Card for Authnet but it failed. I ended up using a real card and there was no problem.
So, error logging would be useful or even more detailed rejection response handling from Gateways. Anything I need to set, turn-on or recode to get a more accurate error response?
see the "Debugging eCart transaction failed issues" tutorial on the eCart support page:
ecart/
Steve
Great help you have been today Jason.
Thanks!!
you're welcome.
