Custom HTML Form
Thread begun 12/15/2010 12:52 am by rmruda390861 | Last modified 12/16/2010 7:13 am by Jason Byrnes | 2110 views | 3 replies |
rmruda390861
Custom HTML Form
Using Universal Email 4 to send email from a form created with CSS Form Builder 1.x
Everything works fine with the standard email template (used block.php) but since this is not very clean I designed my own form using DW html from within your app..
All the fields I needed came out on my HTML form OK except for the field which is type "list" (has a number of products to choose from)
Now there is a difference in the code for this list field when I drag if from the Bindings panel
(see Product below, below Telephone - telephone works fine)
You can see that Product has an extra [].
If I manually remove the [] the form is emailed with the word "Array" in the product field which makes sense
If I leave it with the [] then the form is emailed empty in the product field
How do I bind the field which I guess is or could be an array of more than one product??
I also see in the preview panel within Universal email, "Dynamic Value" appears next to product..
You template form block.php handles the products field just fine by listing one product after the other..
<td>Telephone</td>
<td><?php echo ((isset($_POST["Contact_Us_group_Telephone"]))?$_POST["Contact_Us_group_Telephone"]:"")?></td>
</tr>
<tr>
<td>Product</td>
<td><?php echo((isset($_POST["Contact_Us_group_Product[]"]))?$_POST["Contact_Us_group_Product[]"]:"") ?></td>
</tr>
<tr>
Richard
a multiple select list creates an array of the selections that where made.
the default template has code in place to convert the array to a comma seperated list using the implode() function.
you will need to edit:
<?php echo((isset($_POST["Contact_Us_group_Product[]"]))?$_POST["Contact_Us_group_Product[]"]:""?>
<?php echo((isset($_POST["Contact_Us_group_Product"]))?implode(", "$_POST["Contact_Us_group_Product"]):""?>
to convert the array.
rmruda390861
Jason,
Thanks it worked fine.
Just want your comment on point 1 but documenting point 2
1) With testing the emails are not consistently arriving - I am testing with emails being sent to gmail. Some are caught in Spam which is OK but others are not arriving at all. (surely gmail are not dropping some of these totally??). Perhaps if too many are sent over a short period of time then gmail assumes a spider of sorts. Opinion please?
2) The file I edited "contact_WAUE_HTML_WA_Universal_Email_1.php" disappeared after the first form send after editing your changes (local and on server (or was not visible for some reason - I checked carefully) and of course the email did not arrive the 2nd time I tried thsi because the file was not there.
I open up Universal Email again, clicked on DW to edit and it loaded in the window again showing the saved changes but after saving again it did not show in any file browse???. I closed DW completely and opened again and all appears normal now.
1) I dont think the issue is with gmail, it is more likely an issue with the smtp server being used. to determine why the smtp server is not relaying some of the emails, you would need to contact the host to have them look into the smtp server error logs.
2) I have no idea why the file would not be in the Dreamweaver file browser, but it seams that restating Dreamweaver fixed the problem.
