Markers not showing up on google maps
Thread begun 12/12/2010 6:31 am by frenchboi419631 | Last modified 3/30/2012 2:18 pm by Jason Byrnes | 4795 views | 5 replies |
frenchboi419631
I have recently brought and installed the google maps extension for dream weaver, everything works fine except the markers are not visible, multiple markers work, and the address bar works, just no marker images show up regardless of what combination of colour or shape.
The map is currently on www.anglingclub.co.uk on the forum page.
Any help would be greatly appreciated
it doesn't look like the google_javascript/images folder is uploaded to the server.
make sure to upload the entire google_javascript folder.
frenchboi419631
Thank you
Thank you for your speedy reply, it worked well. Your help is Greatly appreciated. Peace out
Brad Lawryk
I am having the same trouble but the folders have been uploaded. It doesn't work locally either and I have double checked that the images are there.
Just the pins/flags just don't show up. Other than that it works perfectly for what we need.
Brad Lawryk
I discovered it has to do with the map being included using framework. the page on its own works fine. Any ideas how to fix that?
this s a bug that i have logged in our bugbase, the fix is to edit the map js file to change the path to the map images to use a full url.
if you are unsure what needs to be changed, send a link where i can seethe problem and investigate the code and I can tell you what to change.
