Shipping in 5.0.3
Thread begun 12/11/2010 10:19 am by malcolm230194 | Last modified 1/31/2011 6:37 am by Ray Borduin | 5628 views | 10 replies |
malcolm230194
Shipping in 5.0.3
Checkout wizard always produces base shipping and per item supplement in read only cart. How can I get shipping to show as summary only?. Right now I have to run display manager and delete original form and replace with form generated in display manager.
It also generates a syntax errors in the email code starting at the line below.
$RecipArray[$CurIndex][] = $row_<?php echo ((isset($_SESSION["eCartCheckoutForm_firstname"]))?$_SESSION["eCartCheckoutForm_firstname"]:"") ?>
There is no email server behaviour
It sometimes generates a checkout page with no shipping address form.
Sometimes after finishing the wizard it just exits and does nothing.
All the above are with no payment selected.
With payment selected there is no email option.
I've deleted and reinstalled both CSS form designer and eCart, deleted .dat file, then reinstalled both extensions.
Is this really a bug fix?
cal114936Beta Tester
There is no email server behaviour listed in server behaviors even though it was supposed to be. Is this the result of the syntax error above?
Was there a solution to this problem/ Could you post it?
Yes, this syntax error prevents the server behavior from opening. We will be coming out with an update to address this bug after the holidays.
In the meantime I think you can probably update it to:
$RecipArray[$CurIndex][] = "";
and that will allow you to open the email server behavior and set the to address to:
We also have a beta version of eCart that you can download that will produce the correct code from the wizard.
Ok tried this.
Replaced:
With:
The syntax error moved to the next line and the email server behavior didn't show.
Here is the block of code for the email server behavior.
if (!isset($_SESSION))session_start();
if ((($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST))) {
//WA Universal Email object="mail"
set_time_limit(0);
$EmailRef = "waue_confirm_5";
$BurstSize = 1;
$BurstTime = 200;
$WaitTime = 1;
$GoToPage = "";
$RecipArray = array();
$StartBurst = time();
$LoopCount = 0;
$TotalEmails = 0;
$RecipIndex = 0;
// build up recipients array
$CurIndex = sizeof($RecipArray);
$RecipArray[$CurIndex] = array();
<?php echo ((isset($_SESSION["eCartCheckoutForm_lastname"]))?$_SESSION["eCartCheckoutForm_lastname"]:"") ?>|WA|<?php echo ((isset($_SESSION["eCartCheckoutForm_email"]))?$_SESSION["eCartCheckoutForm_email"]:"") ?>;
$RecipArray[$CurIndex][] = $<?php echo ((isset($_SESSION["eCartCheckoutForm_firstname"]))?$_SESSION["eCartCheckoutForm_firstname"]:"") ?><?php echo ((isset($_SESSION["eCartCheckoutForm_lastname"]))?$_SESSION["eCartCheckoutForm_lastname"]:"") ?>|WA|<?php echo ((isset($_SESSION["eCartCheckoutForm_email"]))?$_SESSION["eCartCheckoutForm_email"]:"") ?>;
$RecipArray[$CurIndex][] = "undefined";
$TotalEmails += mysql_num_rows($<?php echo ((isset($_SESSION["eCartCheckoutForm_firstname"]))?$_SESSION["eCartCheckoutForm_firstname"]:"") ?><?php echo ((isset($_SESSION["eCartCheckoutForm_lastname"]))?$_SESSION["eCartCheckoutForm_lastname"]:"") ?>|WA|<?php echo ((isset($_SESSION["eCartCheckoutForm_email"]))?$_SESSION["eCartCheckoutForm_email"]:"") ?>);
$RealWait = ($WaitTime<0.25)?0.25:($WaitTime+0.1);
$TimeTracker = Array();
$TotalBursts = floor($TotalEmails/$BurstSize);
$AfterBursts = $TotalEmails % $BurstSize;
$TimeRemaining = ($TotalBursts * $BurstTime) + ($AfterBursts*$RealWait);
if ($TimeRemaining < ($TotalEmails*$RealWait) ) {
$TimeRemaining = $TotalEmails*$RealWait;
$_SESSION[$EmailRef."_Total"] = $TotalEmails;
$_SESSION[$EmailRef."_Index"] = 0;
$_SESSION[$EmailRef."_Remaining"] = $TimeRemaining;
while ($RecipIndex < sizeof($RecipArray)) {
$EnteredValue = is_string($RecipArray[$RecipIndex][0]);
$CurIndex = 0;
while (($EnteredValue && $CurIndex < sizeof($RecipArray[$RecipIndex])) || (!$EnteredValue && $RecipArray[$RecipIndex][0])) {
$starttime = microtime_float();
if ($EnteredValue) {
$RecipientEmail = $RecipArray[$RecipIndex][$CurIndex];
} else {
$RecipientEmail = $RecipArray[$RecipIndex][0][$RecipArray[$RecipIndex][2]];
$EmailsRemaining = ($TotalEmails- $LoopCount);
$BurstsRemaining = ceil(($EmailsRemaining-$AfterBursts)/$BurstSize);
$IntoBurst = ($EmailsRemaining-$AfterBursts) % $BurstSize;
if ($AfterBursts<$EmailsRemaining) $IntoBurst = 0;
$TimeRemaining = ($BurstsRemaining * $BurstTime * 60) + ((($AfterBursts<$EmailsRemaining)?$AfterBursts:$EmailsRemaining)*$RealWait) - (($AfterBursts>$EmailsRemaining)?0:($IntoBurst*$RealWait));
if ($TimeRemaining < ($EmailsRemaining*$RealWait) ) {
$TimeRemaining = $EmailsRemaining*$RealWait;
$CurIndex ++;
$LoopCount ++;
session_commit();
session_start();
$_SESSION[$EmailRef."_Index"] = $LoopCount;
$_SESSION[$EmailRef."_Remaining"] = round($TimeRemaining);
session_commit();
wa_sleep($WaitTime);
include("webassist/email/waue_confirm_5.php");
$endtime = microtime_float();
$TimeTracker[] =$endtime - $starttime;
$RealWait = array_sum($TimeTracker)/sizeof($TimeTracker);
if ($LoopCount % $BurstSize == 0 && $CurIndex < sizeof($RecipArray[$RecipIndex])) {
$TimePassed = (time() - $StartBurst);
if ($TimePassed < ($BurstTime*60)) {
$WaitBurst = ($BurstTime*60) -$TimePassed;
wa_sleep($WaitBurst);
else {
$TimeRemaining = ($TotalEmails- $LoopCount)*$RealWait;
if (!$EnteredValue) {
$RecipArray[$RecipIndex][0] = mysql_fetch_assoc($RecipArray[$RecipIndex][1]);
$RecipIndex ++;
$_SESSION[$EmailRef."_Total"] = 0;
$_SESSION[$EmailRef."_Remaining"] = 0;
session_commit();
session_start();
if ($GoToPage!="") {
header("Location: ".$GoToPage);
I'll create a support incident and work with you directly to make sure this issue is resolved.
danny405167
Did you get a solution to your problem?
I am having the same problem. I am running snow leopard and cs5.
I have opened a support ticket so we can look into this issue with you as well.
We have released a new build of eCart so that this problem will no longer happen.
If you already ran into this issue and don't want to run the wizard again you should be able to replace:
with:
$RecipArray[$CurIndex ][] = "".((isset($_SESSION["eCartCheckoutForm_email"]))?$_SESSION["eCartCheckoutForm_email"]:"")  ."";
$TotalEmails += sizeof($RecipArray[$CurIndex]);
danny405167
Sorry but the problem is still persist
The Ecart 5.0.3 does not fix the problem, but the version 5.0.4 does. My suggestion is to work on and finish 5.0.4.
