Downloading PDFs using DFP with results from DataAssist Search
Thread begun 12/09/2010 3:05 pm by YellowCircleWeb | Last modified 12/10/2010 7:01 am by Jason Byrnes | 1946 views | 1 replies |
YellowCircleWeb
I've created a search page to allow users to enter a product code and search for parts in a database. A results page is then generated listing each of the pages. The product code the user enters in the search form corresponds with the name of a PDF file which I have located in directory outside of the website root folder.
I'm trying to use Digital File Pro to allow the downloading of a the PDF file for the part code. I got it working on a development machine when I wasn't using DataAssist Search functionality.
However, on my DataAssist results page there is code that sets a session variable relating to the search page when the POST method is invoked, so whenever I click the download button on the results form (with the trigger for DFP set to 'current page submit') the search code is executed, rather than the download code and every single record is returned because I've not entered any search term.
I've looked at this post by Jason showpost.php?p=19527&postcount=11 and that's what helped me to get it working without using DataAssist, but in the actual website I need DataAssist search functionality in order to find the part codes. (hope all that made sense).
I've attached a copy of all of the pages involved in this. How can I get the DFP download functionality to work rather than the DA search functionality?
you have to be creative with the triggers.
since the search only uses one form element, set the to trigger on that form element.
On the results page, go to the binding panel and click the plus button, select Form Data.
In the form data wizard click the folder icon an select the search page.
this will create a binding group for the form from the search page on the results page.
Now in the data assist search wizard, click the lightning bolt next to the trigger selection and select the S_BomReference form element from the search page.
