Text in one line
Thread begun 12/06/2010 6:53 am by PeterL | Last modified 12/09/2010 12:32 pm by Jason Byrnes | 3785 views | 7 replies |
PeterL
Text in one line
hello,
i am using Universal email 4.0 for the first time and I got a few problems;
firts of all; how can i modify Universal email afterwards (with UE 3 you could click the script item)
my second question is why de texst in the emal is in one line and not beneath each other
(see attachement)
Thanks,
PeterL
to edit the universal email settings, double click the universal email server behavior in the server behavior list.
Please send a copy of your page and the webassist/email folder in a zip archive so i can examine the code to see why it is on one line.
PeterL
Jason, of course, it always was like that; I had forgotten.
Oke, Here are the files
Thanks for your help again!!
PeterL
in the waue_contact_1.php file, try changing:
$MailBody = $MailBody . (str_replace("_"," ",$pkey).": ".($pval));
$MailBody = $MailBody . (str_replace("_"," ",$pkey).": ".($pval)."<br/>");
PeterL
Hello Jason,
indeed, now it is perfect!
I made some change myself so it looks even better:
$MailBody = $MailBody . (str_replace("_"," ",$pkey).": ".($pval)."<br/><br/>");
Thanks!!
P.S.: Is this a permanent problem or is it just a coincidence?
Next: when i make changes in WA_UE i get an error:
Parse error: syntax error, unexpected $end in /home/httpd/vhosts/mysite.com/subdomains/nieuw/httpdocs/webassist/email/waue_contact_1.php on line 82
Also the script feeld has changed:
<?php foreach( $_POST as $pkey => $pval ) { ?>
<?php echo (str_replace("_"," ",$pkey).": ".($pval)."<br/><br/>")?>\r\n
I have to correct this manualy!?
PeterL
the mail program should converting the \r\n to a line break.
i cant say why the mail program is not reading the new line character as a line break, the work around is to make the edit I suggested.
perhaps you should try selecting the option to create a file for the email message and choosing one of the prebuilt templates.
PeterL
Jason,
i can live with that.
Thanks and good luck!
Peter
Ok, you're welcome.
