Minimum version of PHP required ?
Thread begun 12/06/2010 3:29 am by Dave Buchholz | Last modified 12/07/2010 7:39 am by Dave Buchholz | 1718 views | 2 replies |
Dave BuchholzBeta Tester
It doesn't seem to like 4.4.9 which is what my client has installed !
Error Message: Parse error: syntax error, unexpected T_STRING, expecting T_OLD_FUNCTION or T_FUNCTION or T_VAR or '}' in /home/########/public_html/webassist/framework/framework.php on line 3
Framework files use classes and objects, which weren't introduced until php 5 (July 13 2004). Most ISPs use php 5 at this point, or will upgrade to php 5 without a charge... can you convince your client to upgrade to php 5? There are quite a few advances made in the past 5 years besides classes and object abstraction that have been added not to mention efficiency improvements.
Thanks Ray, the issue is that the client has used the cheapest, crappiest host you can imagine so a transfer to my server would be in order I think.
