Need help on with option with price increment
Thread begun 11/28/2010 3:27 am by rikaG_510 | Last modified 12/02/2010 5:05 pm by Dani Chankhour | 2172 views | 3 replies |
rikaG_510
Sorry, I forgot to fix the title, which is supposed to be;
Need help on options with price increment.
My sites are to sell bolts, for example,
6x70 rigger bolts $2.00
6x80 rigger bolts $2.50
I've managed to deploy options with radio button, but I don't know what I have to do next to apply the price increment to Add to cart button.
I saw some other posts talking about the same kind of topics, but everybodoy has different way of approaching, I still can not figure out.
I made database as below, with price increasment in Product Option table.
[Products]
ProductID
ProductCategory
ProductName
ProductDescription
ProductPrice - Base price for products
[OptionsGroups]
OptionGroupID - Primary Key
OptionGroupName
[Options]
OptionID
Option_OptionGroupID
OptionName
[ProductOption]
ProductOptionID
ProductID
ProductOption_OptionGroupsID
ProductOptoin_OptionID
ProductOptoin_PriceIncrement
Here is the code for one of my options;
<form style="display:inline" name="Swift_4_ATC_<?php echo $row_rigger4_50["ProductID"]; ?>" method="POST" action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""; ?>">
<?php do { ?>
<dl class="option_radio">
<dt><input type="radio" name="Swift_4_Select_Add" value="<?php echo $row_rig50_option['OptionName']; ?>" /></dt>
<dd><?php echo $row_rig50_option['OptionName']; ?>&nbsp;&nbsp;$<?php echo $row_rig50_option['OptionPrice']; ?></dd>
</dl>
<?php } while ($row_rig50_option = mysql_fetch_assoc($rig50_option)); ?>
<div class="prd_cart">
<input type="text" name="Swift_4_Quantity_Add" value="1" size="4" />
<input type="submit" class="eC_FormButton" value="Add to list" name="Swift_4_ATC">
<input type="hidden" name="Swift_4_ID_Add" value="<?php echo $row_rigger4_50["ProductID"]; ?>" />
</div>
</form>
I cannot write PHP code, so I need a big help.
What would be the next step?
The Add to cart button and checkout are working just fine.
I just need to figure out how to populate different price on each option.
Thank you,
Rika
Dani Chankhour
Have you followed this tutorial:
product_options.php
this tutorial should help in getting started, as you can see the last part talks about adding a select list but you can ignore that since you already have radio buttons. But you should be able to get the price increment working following that tutorial.
Let me know if you have any other questions.
rikaG_510
Hi Dani,
Oh. I did not know this tutorial existed.
Is it new?
Anyway, thank you and I will try with this first.
Rika
Dani Chankhour
It is not new, but it is not old.
I hope it helps.
