Data Assist - Issue creating unique profile pages for users
Thread begun 11/26/2010 1:59 pm by hbibizadeh396670 | Last modified 11/30/2010 5:12 pm by Jason Byrnes | 6917 views | 12 replies |
hbibizadeh396670
I have created a social networking site using Data assist which allows people to upload images, videos, etc... To the site which can be viewed by the public in a gallery. The system has been built using multiple database tables. However I have run into an Issue.
I am struggling to set up profile pages.
When a person views an image detail page from an Image database table, they have an option to click on the user’s username and be redirected to that users profile page where information from another user database table needs to show. (First, Last Name, etc...)
In this system I am trying to combine two database tables, I need the system to show the right users profile according to which username has been selected in the image gallery, and then display that users information from another database table.
So Far I have achieved:
I have used a user registration system database table and an image database table in this instance.
I have used both the registration table for the creation of users and profile pages. When a person registers with the site, it creates a record in the table,
Once the user is logged in they are able to access a "Set up profile" page, (an update data assist page), which updates certain fields in the record, which the profile page needs to show.
So far, people can create their profile page, the information inserts in the table fine, however I cannot show the right information for the write profile page,
To link the detail pages to the profile page I have used the following link
../PublicPhotosProfilePages/PublicPhotosProfilePage.php?CustID=<?php echo(rawurlencode($row_WADAimagetable['CustID'])); ?>
Then in the profile page I have created two record sets, One for the image table, the other for the user table.
I inserted a text field which dynamically show the users user name from the session variable brought from the detail page,
A cookie from “Cookies tool kit” which dynamically picks up the users ID from the image table.
<?php echo $row_WADAimagetable['UserID']; ?>
And then I filter the users database table record set off the cookie I created.
However this does not seem to work. Sometimes information shows sometimes for the wrong user and other times not at all.
Please tell me what I am doing wrong.
Thanks in advance!
When a user logs in, the user ID is stored in a session variable.
When the profile ios created, you should be using this session variable as the users ID.
You should also be using that session variable to filter the recordsets. That session variable is the link to the users unique ID.
hbibizadeh396670
Thanks for the reply but I think you might have miss understood what I am trying to do.
I am not trying to show the logged in users ID but other people profiles.
You see I have created a social networking site where people upload images, videos, etc...
What I have made is an area where people see all the results uploaded to the site by all site users.
When a person selects one result and goes to the detail page, they have the option to click on the uploader of the file being viewed and visit there Profile page which contains the information of that or another user.
I think if I use the session variable of the profile page, the person would only see their own information, which is not what I am trying to do.
Thanks in advance
hbibizadeh396670
is this possible
hbibizadeh396670
Very similar to the way people see youtube profile pages
i think the issue is in using the cookie.
your link to the detail page aleady passes the user id as the CustID querystring variable
just use that querystring variable for filtering the recordsets.
hbibizadeh396670
To try and make it work, I have created a new profile page. The pages has two record sets. One for the users table and another for the image table.
I have tryied to filter the user ID from both recorsets usinng the session variable of Cust ID "imagetable_CustID" and the "UserID" which is avalible.
After this I select the fields in the user table and insert them to the page.
When I run the system, I just get a blank page.
What is wrong?
dont use the session variable.
use the CustID query-string variable.
when a page displays blank, it means a php error is occurring but error reporting is turned off.
add the following code at line 1 to turn error reporting on:
error_reporting
(E_ALL);
hbibizadeh396670
Ok I did that but I dont get any errors
I dont know how to add CustID query-string variable
I have uploaded the profile page to see if you require
hbibizadeh396670
Actually I have been trying different things and I think I have got the error
Warning: mysql_free_result(): 4 is not a valid MySQL result resource in C:\wamp\www\KittyCatSpace\PublicPhotosProfilePages\PublicPhotosProfilePage.php on line 252
Warning: mysql_free_result(): 5 is not a valid MySQL result resource in C:\wamp\www\KittyCatSpace\PublicPhotosProfilePages\PublicPhotosProfilePage.php on line 254
Not sure what this means
