Javascript error line 258
Thread begun 11/23/2010 3:15 pm by willo009412397 | Last modified 1/14/2011 12:46 pm by peterbroekman35409717 | 2889 views | 4 replies |
willo009412397
Hi
I have a problem with securityAssist when running the wizard, i get this msg
while executing onload in securityAssist wizard.htm, the following javascript error occurred at line 258 of file.
Col_list. options[Col_list.selectedIndex] has no properties.
It must be someting simple, as ive had it running before now, i just cannot find what it is.
Thanks for any help
karl
Dani Chankhour
This seems to be a Dreamweaver bug. Please check your database that you are trying to use and if you are using a column that stores values such as forward slashes ('/'), replace them with ('//').
willo009412397
Thankyou
Thankyou this worked for me.
Dani Chankhour
I'm glad i was able to help. Make sure to account for the extra forward slashes when you you use that column. Or you can just make that change on your local server and not on your live server database.
Please spell out the above and below thread on your official documentation. Don't let people look for ages to find out the provided blue_sky_music.sql database actually contains the slash causing dreamweaver to show this annoying javascript error. Once deleting the connection to this database / altering the values of the table it worked for me. It might be a good idea to change the values in this database. The table genres contains a / and Dreamweaver (although it seems a dw bug) then gives this mistake. Tnx in advance.
showthread.php?t=5334
