will power gallery work with my cms?
Thread begun 11/19/2010 11:49 am by segalmedia367166 | Last modified 11/19/2010 1:13 pm by Jason Byrnes | 1769 views | 1 replies |
segalmedia367166
my client is using squarespace.com for their site. their galley is not a robust as powergallery. can i add powergallery to their site? here is whatn squarespace told me:
"There's not a slideshow feature within the system. However, you can add any third party solution that offers direct embed HTML or client side javascrip".
Lisa
that depends on how much access you have to the code that is used to output the cms to the site.
In order to use PowerGallery in early versions of power cms, you would need to add the Database integration update that is available in the download center.
you would need to wrap the wa_avaulate function around the code that outputs the cms data, for example:
<?php require_once('wa_evaluate.php'); ?>
<?php echo wa_evaluate(<cms code here>); ?>
if your cms system does not give this sort of access, then no, power gallery wont be able to work.
