Attaching email problem
Thread begun 11/11/2010 2:27 pm by kata387222 | Last modified 11/15/2010 1:05 pm by Jason Byrnes | 1840 views | 3 replies |
kata387222
Hi. I am having a problem with a form built with Form Builder. When an attached PDF file is sent it gets corrupted over email. Other file types seem to work OK. I have successfully sent pdfs using another form created using only universal email to add the functionality. Your assistance will be much appreciated. I have attached the code of both files.
can you compress the original php files and the webassist folder into a zip archive and send that please so i can examine the code.
kata387222
ZIP attached for code. Thanks
I'm wondering if a php error is occuring.
Change the line for the redirect:
$GoToPage = "thanks.php";
$GoToPage = "";
then add the following code at line 1:
error_reporting
(E_ALL);
ini-set('display_errors','on');
report back any errors that are displayed on testing.
