Language problems by sending a Form
Thread begun 11/09/2010 2:27 pm by studer283031 | Last modified 11/10/2010 8:27 am by Jason Byrnes | 2545 views | 3 replies |
studer283031
Dear all
I've createt a form with CSS Formbuilder 2.
scb_contact_us.php
This Form will be send to me and back to the sender (dynamic EMail address). This works. I works with the default template, but when I received the eMail all the label are in English and a lot of understanding words on body. I've read the manuel, see the video and spend a lot of time in this forum, but I found never a solution. Can anybody help me. What do I wrong. When I disable the template no EMail will be send.
Thanks in advance
Paul
the label that is displayed in the email is taken from the form element name.
If you edit the form contents, select each group and click the edit button. Here you can select each form element for the group and set the Label and Name manually.
you can edit the other aspects of the email by editing the template file that is created in the webassist/email/templates folder.
studer283031
Thanks for your Help. After two Days the Formualar is created. :-) Now I have only to change the submitted time and date.
Thanks a lot again.
Paul
you're welcome.
