Not sending data to multiple receipients
Thread begun 11/05/2010 3:27 am by ljvoostende321886 | Last modified 11/29/2010 6:50 am by Jason Byrnes | 4139 views | 8 replies |
ljvoostende321886
Hello,
I am trying to make a personalized newsletter for my website.
But when I send out the emails it loops alright through the emailadresses but not the other fields like name, etc.
It only collects the data from the first record.
I have searched the forum and read some other posts with the same problem.
Seems to be a problem with UE4.
Is there already a solution for it?
Loet van Oostende
PS.
I have tried the solution with $RecipArray[$RecipIndex][0] and that is working now.
A lot of extra work but now I can do something with the newsletter.
It only does not sent all the emails, in my test 3 out of 4.
The progressbar shows 4 but I receive only 3 emails.
I think it skips the first or last record.
When the email is getting sent successfully to some addresses but not to others, it points to an issue with the SMTP server. For some reason the SMTP server is not relaying the message to the 4th recipient. You should contact the host to look into the smtp server error logs to see why the email is not being relayed to the 4th email address.
ljvoostende321886
Hello Jason,
My problem is not SMTP related.
I have a test table with 4 records and a membertable with over 900 records.
All the emails form both the tables are sent.
The reason it skipped 1 was something with the emailaddress.
The real problem is that when sending the emails from a recordset it does not get the data from the records, only the emailadresses loop.
So when I want to put for example the names and other information from the recordset in the message it only uses the data from the first record.
So it sends all the emails with the data from the first record.
I know it worked in UE3 before when I did some tests some time ago but did not use it any further.
But now I have to handcode the code in the waue_mail.php and replace all the recordnames with $RecipArray[$RecipIndex][0]
Loet
diamou_fr200291
Hello,
I have the same issue, could you please help me?
Thanks!
send a copy of your page and the webassist/email folder in a zip archive so that I can see the code.
diamou_fr200291
Hi Jason,
Thanks for your quick reply. Find the files in question in the attachments.
The e-mail is sent but the dynamic data of the first record is sent to all. I want the system to send each data to its specific user.
Thanks in advance
in the webassist/email/waue_envoyer-verification_2.php file, change the recordset reference:
$row_rsNoVrif
so for example, this line:
$MailBody = $MailBody . $row_rsNoVrif['uEmail'];
would be changed to:
$MailBody = $MailBody . $RecipArray[$RecipIndex][0]['uEmail'];
diamou_fr200291
Hi Jason,
Thanks a lot for your help. It works now!
Just one question, WA_UE does not do this automatically? Meaning, I have to change this manually every time?
Yes, this will need to changed manually every time.
