Database Connection
Thread begun 11/03/2010 10:51 am by dchaplin246817 | Last modified 11/08/2010 3:30 pm by Dani Chankhour | 2207 views | 3 replies |
dchaplin246817
Database Connection
I am using CS5 and cannot get DataAssist connection to work. I keep getting an error on invalid user or password.
I have added my IP's at the host and I am able to make a connection with NAVICAT & OBDC connector.
It seems like it is trying to login as username@domain_name.com
It is such a simple design I really did not want to setup a local server which appears to be the only answer I have seen so far in the forums.
I have used this product for years and this is the first I have seen this. Is it a CS5 issue?
UPDATE:
I installed MySQL on my development system, connected NAVICAT and copied all of the database and tables to localhost
I tried to create a localhost connection and I get a 1045 error Access denied WTH
Why do all of the tools work but CS5 / Data Assist will not
Dani Chankhour
If you are able to define a connection outside of the DataAssist wizard, are you able to select the connection in the DataAssist Wizard? or do you get the error when you select the connection in DataAssist Only.
dchaplin246817
Yes
I tried it in DreamWeaver with same results.
Also tried the new Dynamic Connections App from WA witht the same result
MySQL Error: 1045
Access denied for user 'discou80_egcdata'@c157.justhoust.com'(using password: YES)
please help
Dani Chankhour
I have opened a support ticket to further assist you with this issue:
