Menu is missing when creating a Custom Site Sculptor Design
Thread begun 11/02/2010 12:47 pm by Rune Brynestad | Last modified 11/05/2010 10:33 am by Dani Chankhour | 3139 views | 7 replies |
Rune Brynestad
I have the Sporty Website design located in My Downloads. The design includes Presets for CSS Scolptor and Css Menu Writer. I have successfully imported them into Css Sculptor and Css Menu Writer using the Preset Manager. I have checked them using the related extension and they looks good.
I want to use them to create a custom Site Sculptor design. You can see what I do step by step here:
step-by-step.php
I have attached my Css Sculptor Pesets, Menu Writer Preset and my newly created Site Sculptor Preset so you can see if you can reproduce the problem.
Thanks in advice.
Regards
Rune
Dani Chankhour
I followed the same exact steps that you took but i was not able to reproduce the issue. Could you please tell me what version of Menu Writer and CSS Sculptor you have installed?
Rune Brynestad
Css Sculptor: 3.0.2
Css Menu Writer: 2.0.5
Dani Chankhour
Thanks. I just wanted to make sure you were the latest version.
could you please export the Site Sculptor Deign and attach it to this post.
Thanks.
Rune Brynestad
Here it is again. It's also attached to my first post.
Dani Chankhour
sorry i did not see it in your first. I was able to reproduce the issue you are having with the menu not getting generated on the content pages.
to fix this issue, i have attached a wa_sitesculptor_menuwriter.js file that have the fix.
With Dreamweaver closed, please replace your wa_sitesculptor_menuwriter.js file with the attached file which is located under your configuration/commands folder, delete the cache file and start DW. You will need to recreate the site sculptor design.
Rune Brynestad
Works perfect!
Thanks again for helping me.
Regards
Rune
Dani Chankhour
I'm glad i was able to help.
The fix should be included in our next dot release.
