" /> added to checkout button
Thread begun 11/01/2010 3:53 pm by art391139 | Last modified 11/02/2010 7:10 am by Jason Byrnes | 1409 views | 1 replies |
art391139
I have one product that I set-up in powerstore that displays " /> plus the shopping cart description just to the left of the checkout button on the cart page. This does not happen with any other of my 110 parts. When I point to a different table it goes away. I have both recreated the page and the deleted and recreated the part number in Powerstore and it still shows up just for this part number. If I delete the cart description all together I still get " /> to the left of the checkout button.
On a separate note when I CC or BCC my confirm e-mail a copy doesn't come to me and I have tried as suggested in another post changing the e-mail so that it is not the same one in and out.
check the database directly for that particular item and make sure the information in the data base for the name and the cart description is correct.
If you could export the record for that item we could take a look to find the problem .
Is the email going to main recipient? Just not the cc or bcc address?
have you double checked the spam folder to make sure it's not being treated as spam?
if it sends to the main recipient, but not the cc or bcc address, there may something on the SMTP server that is causing the failure. Check with your host to see if they can look into the smtp error logs to see why the email is not being relayed by the smtp server.
