R6025 Pure Virtual function call
Thread begun 10/30/2010 1:50 am by clive.bramley406111 | Last modified 11/01/2010 10:17 am by Jason Byrnes | 2004 views | 2 replies |
clive.bramley406111
when using the data assist wizard when you click finish you get a c++ error message
R6025 Pure Virtual Function Call.
I have only just purchased data assist and so far not impressed..
Please help..
Ive tried a lot of the thing on the forum
but still no luck
clive
neilo
Hi Clive,
Can I just check that you have tried (with Dreamweaver closed) deleting the WinFileCache file?
If not, delete the file at:
C:\Users\Your User Name\AppData\Roaming\Adobe\Dreamweaver CS5\en_US\Configuration\WinFileCache-XXXXXXXXX.dat (where XXXXXXXXX is some alpha-numeric characters)
Delete the file, and then re-open Dreamweaver and try again. You may have already tried this, but it would be remiss not to check . . .
This is a very annoying error that we have not been able to find any one specific cause for.
If deleting the cache file as neilo suggested does not correct the issue, try renaming the configuration folder:
Configuration_back
Then uninstalling data assist from the extension manage rand installing it again.
