PS3 - Name field truncates everything after a quotation mark
Thread begun 10/27/2010 1:33 pm by terry164844 | Last modified 10/28/2010 11:18 am by Jason Byrnes | 3353 views | 4 replies |
terry164844
Help - I enter in a product and put the name. The name has a quotation mark for inches 10" and then wording after that. When I pull up the product again to update the product, everything after the quotation mark is truncated.
What do I need to do to resolve this?
Terry
This is fixed in the PowerStore 3.01 update that was recently released.
Please log into the download center to download the updated power store files.
terry164844
Excellent thank you!
On the 3.01 are these just the files that are updated / fixed or the entire site? If there were mods to the files will they be overwritten?
Thanks for your help,
Terry
terry164844
Also...I noticed in the fixes that it says:
Corrected an issue that caused quotation marks used in product option names to break the admin options page.
The problem is not that is breaks the admin options page, but that it truncates everything after the quotation mark.
I did some troubleshooting and when the data in the field comes in on the sql statement it is in its full text and nothing is missing.
Only when it's displayed in the input field does it get truncated.
I suspect it's because the value=" is looking for the ending " to close the value. That makes sense...
I'm wondering if this actually got fixed in the 3.0.1 release because it doesn't appear to be the case. Plus...how in the world would you fix this?
oh wait...I just tried something. On the input field and the value= I put a single quote around the php statement and that worked.
=== code start ===
<input type="text" name="ProductName" id="ProductName" value='<?php echo(isset($_GET['valid'])?ValidatedField("ProductsUpdate","ProductName"):$row_WADAProducts['ProductName']) ?>' size="32" onblur="if (document.getElementById('ProductNameServerValidation')) document.getElementById('ProductNameServerValidation').style.display='none';" />
=== code end ===
you started another thread on this issue here:
showthread.php?t=16821
see my reply there.
