Captcha doesn't show
Thread begun 10/26/2010 3:05 pm by esms | Last modified 11/14/2011 7:30 am by Jason Byrnes | 9004 views | 30 replies |
esmsBeta Tester
Hello,
Even though I have duplicated the exact same settings from one form that Jason managed to get working for me after it didn't work, I have now set up a form on a completely different site.
But, the captcha image doesn't show! As I say, I have created a brand new form in a different site and duplicated the settings from the previous site.
contactform.php
How do I make the captcha image show?
esmsBeta Tester
Just noticed someone else has experienced the same problem. Was it resolved?
showthread.php?t=16554
when i try to view the image directly:
wavt_captchasecurityimages.php
i get an error saying:
The image “wavt_captchasecurityimages.php” cannot be displayed, because it contains errors.
We will need to know what those errors are to find a solution
try adding the following code to the webassist/captcha/wavt_captchasecurityimages.php file at line 1:
error_reporting
(E_ALL);
esmsBeta Tester
Hello,
OK - I've added the code. What do I look for?
I'm sorry, i has a syntax error in the code I gave yo, change it to:
error_reporting
(E_ALL);
let me know when you have made that change and I will take a look.
esmsBeta Tester
Hello,
I copied and pasted again. My eyes must be deceiving me but I couldn't see any difference.
Is this any better?
esmsBeta Tester
Here's the code view.
the change is the last single quote around on:
'on');
in your screen shot that is missing:
'on);
causing a syntax error.
esmsBeta Tester
Any better?
yes, except you need to add a new closing PHP tag at line 5:
