Custom menu for site sculptor
Thread begun 10/26/2010 4:01 am by saf01 | Last modified 10/27/2010 10:37 am by Jason Byrnes | 2410 views | 5 replies |
saf01
Hi. Please advise. How do I use my own custom made css menu instead of a preset design from css menu writer for use with site sculptor. Can I import my own menu into css menu writer? Thanks.
You would need to create a custom site design using a Dreamweaver template. and create your custom menu design in menu writer.
While creating the custom site design, you have the option to choose the CSS Menu design that will be used.
see the "Creating a custom template for Site Sculptor" tutorial on the site sculptor support page:
site-sculptor/
saf01
ok. thx. Followed this information and successfully created my own css template and tested it site sculptor with preset css menu writer menu. Awesome so far without a glitch.
As for the css menu - after adding the menu wriiter menu - cant I just delete this preset menu and use my menu as a framework plugin on my template (in the place of preset menu) after converting the dwt template and pages to a framework theme instead and then work on the framewrok theme?
Will this work? Please help.
I don't see why this wouldn't work.
saf01
thx, will give this a go
you're welcome.
