PowerStore 3.0.0 issue
Thread begun 10/21/2010 10:18 am by mick106153 | Last modified 10/22/2010 1:20 pm by Jason Byrnes | 1834 views | 3 replies |
mick106153
When updating in Admin. If you place an image in a description area (in my case - long description) and choose to edit that image, all goes well till you decide to position it.
In my case I positioned it to the right and when I than chose to edit it again to add a border and reduce its size, the image was no longer available to edit. I got instead the add image window.
So to make the adjustments I needed to make I had to remove the image and place it again and make all the adjustments before finally positioning i to the right. Once done I checked again and it is now unavailable to edit.
This may have been addressed in 3.0.1 but I don't intend to update for fear of losing my extensive changes.
Mick
Make sure that the image is selected before clicking the Image toolbar button.
you will be able to tell that the image is selected because there will be a bounding box with handles at the top, bottom, left and right of the image.
only if an image is selected will the image toolbar edit the image instead of insert a new one.
mick106153
No, that wasn't it. It was a positioning issue.
I've made some changes so the problem has gone away, but before when I selected the image an area devoid of any content was also selected and by repositioning the image in "Source" view I was able to fix it.
Mick
Ok, glad to know it's working.
