Add to Cart Issue
Thread begun 10/19/2010 1:50 pm by lazyhoofer376912 | Last modified 10/22/2010 7:09 am by Jason Byrnes | 2927 views | 4 replies |
lazyhoofer376912Beta Tester
Add to Cart Issue
When i click add to cart in my store i get this message how do i fix this issue......
and i did update to 4.0.1 and followed the instructions.
Warning: require_once(../../../WA_eCart/WA_cart_coupons.php) [function.require-once]: failed to open stream: No such file or directory in /home/idefine/public_html/love146/webassist/plugins/shopping_cart/cart_editable.php on line 16
Fatal error: require_once() [function.require]: Failed opening required '../../../WA_eCart/WA_cart_coupons.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/idefine/public_html/love146/webassist/plugins/shopping_cart/cart_editable.php on line 16
its seemed to be that there was an issues with something missing within the coding of the webassist/pluggins/shopping_cart/cart_editable.php ......to resolve the problem i replaced it back with the old document and everything worked out just fine. (just giving a heads up to anyone else who experiences this problem)
Jason Kline
this is the same problem I am having. I will post back if this helps.
Jason Kline
This worked for me.
In the update instructions, you copy only the PHP files at the root of the "PowerStore Files" fodler to your existing site and the Admin and HTMLEditor folder.
The webassist/plugins/shopping_cart/cart_editable.php file should not be effected using this method.
