glitch in search menu button?? maybe
Thread begun 10/18/2010 6:52 am by Jason Kline | Last modified 10/18/2010 11:36 am by Jason Byrnes | 3861 views | 7 replies |
Jason Kline
When I scroll up and down the home page the search button gets distorted. See image attached.
what browser are you using?
can you provide a link?
I cant reproduce the issue using Fire Fox or Safari on a Mac.
Jason Kline
I am using IE8 on 1 Win7 2 Vista machines. index.php
the only way i can recreate the issue is to turn on compatibility view in IE8, with compatibility view turned off, it does not happen.
you can try adding the following meta tag to the head of the power store pages:
<meta http-equiv="X-UA-Compatible" content="IE=8" />
which should not allow ie8 to use the compatibility engine.
Jason Kline
Hi Jason,
Can you direct me to the correct PowerStore4 pages to change? So much has changed since PS3 that I want to make sure I change the correct store files the first time.
Thanks.
the 2 templates under webassist/themes/<your theme>/Templates where <your theme is the theme you are using.
Jason Kline
Thank you that fixed it.
excellent, glad to hear that did it.
