What is the proper way to vertically center text?
Thread begun 10/17/2010 6:05 pm by Lon Winters | Last modified 10/18/2010 3:26 pm by Lon Winters | 1661 views | 2 replies |
Lon WintersBeta Tester
In this particular menu I am creating, the item width is 90 and the height is 32 px. Font size is 14 px. Margins and padding all 0.
I set the line height to 32 px, which seems to vertically center the text, but it often takes some trial and error to get the number right to center the text and to not push the height of the item box out.
Is this the proper and best way to vertically center text in the menu?
neilo
I'm not sure if there is a single 'proper' way; my preferred method is to just add a top padding, because the arithmetic is easier.
So in your example (height 32px) if I add 8px top padding, then I reduce the height of the container by 8px = 24px.
You can play with it to get the right numbers, but at least the maths makes sense.
Thanks for the suggestion, I will have to try it again. I think I've shyed away from padding because I haven't yet quote fully grasped the padding concept in CSS.
I think what happened before was that the top pad actually added that much height to the box i5self, so there's still arithmetic involved. But, I will experiment a little more.
