How to Customize PS4
Thread begun 10/16/2010 6:51 pm by lazyhoofer376912 | Last modified 10/18/2010 9:11 am by Ray Borduin | 2980 views | 3 replies |
lazyhoofer376912Beta Tester
I purchased PS4 with hope that i would be able to customize it just as easy as PS2.
Im trying to figure out how to customize the actual theme template itself and its CSS, however everything i do fails. As i designer i want to be able to fully design the site as i invision it, and use PS4 as a Php guidline for the store, coupons, and admin. any suggestions on how to change these themes and make them fully customizable??
elevy388997Beta Tester
I am just getting started in this also, and after you install the store it places the webassist folder in the main area where your site is. So basically, if you are looking at the local files, there is almost no way you will find this. But it is install/webassist/.
Once you install the store, it takes that folder and puts it on its own, so what I did was "get" the folder from the remote site back to my local location.
PowerStore 4 uses the theaming concept from the Framework Builder extension:
framework-builder/
You could create your own theme using framework builder, then apply that theme to powerstore 4
An easier method might be to copy one of the existing themes from /webassist/themes/ and edit it from there.
The templates used are in the /templates/ folder.
Read my post at: showthread.php?t=16199
That will give a more detailed description of the steps.
