Installation Problem with PHP Version
Thread begun 10/14/2010 4:59 pm by lt416410 | Last modified 10/14/2010 7:03 pm by neilo | 2315 views | 1 replies |
lt416410
I bought Power Gallery to run on 1+1 Hosting. On running the install script i got the message that the version of PHP on 1+1 was 4.4.9.
This despite that 1+1 states on their order page that the Linux package supports PHP4 and PHP5.
I contacted their support and receive the following reply:
Thank you for contacting us.
Please be reminded that by default your php version is version 4.4.9. However, you have an option to upgrade this to version 5.2.14 without paying extra cost. To do so, you may refer to the link we prepared for you below. The said link contains the detailed instructions on how to upgrade your php version to version 5.2.14
go.php?t=e614325
Hope this helps. Thank you.
Looking at their FAQ they advise changing file extensions to .PHP5. This I can do, although more work than anticipated.
Which files in Power Gallery do I change?
Thanks.
neilo
I would recommend using their second suggestion, and placing the .htaccess file as described in that link in to your (renamed and) uploaded power gallery folder.
That should then enable smooth running of any gallery you create in the future on that remote site.
  If you don't want to rename all your scripts to .php5, you can do the create a .htaccess file (or edit the existing .htaccess file, if you already have one). You can create this file using a text editor such as Notepad, WordPad, vi, nano, etc. and place the following line in the text file:
AddType x-mapp-php5 .php
Save the text file as .htaccess in the folder where you need to use PHP5 (or upload the file to the correct folder). The settings specified in the .htaccess file are recursive meaning that the settings will apply to the current folder where the file is saved as well as all subfolders.
