Possible Bug
Thread begun 10/14/2010 4:29 am by Dave Buchholz | Last modified 2/11/2011 10:55 am by Jason Byrnes | 5926 views | 9 replies |
Dave BuchholzBeta Tester
Possible Bug
Playing with Image Resizer today on a new site and I set the folder to hold the resize images as "_image_cache" as I like to have these type of folders at the top of the folder tree in Dreamweaver. The folder did not get created and I had to create it myself and apply the necessary permissions.
Using CS5 on Snow Leopard (latest version all patches applied)
I am not able to reproduce the problem, I am also using snow leopard in DW CS5.
I set the cache folder name to "_image_cache" and it was created without an issue.
do you have any other specifics you can offer. Does it happen with other folder names? or only with a leading underscore?
Jason,
I only tried this once, I'll see if I can reproduce this again and come back to you
OK thanks.
danny405167
Image resizer cannot resize an image when I used my mac and cs5
Jason, I too have Snow Leopard and CS5 but when ever I try to re-size an image with image resizer I get the following error
Warning: mkdir(): Permission denied in /Users/danny6995/Development/bfc/webassist/caching/CachedResize_Image.php on line 229 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/Los_Angeles' for 'PST/-8.0/no DST' instead in /Users/danny6995/Development/bfc/webassist/caching/CachedResize_Image.php on line 257 Warning: imagepng(): Unable to open '../../image_cache/Ornamental_Iron/fencing/images/fit/003_w236_h153/003_01080321.png' for writing: No such file or directory in /Users/danny6995/Development/bfc/webassist/caching/CachedResize_Image.php on line 212
If I resize the image with a pc and cs4, I get what I am suppose to. If I copy the files created with cs4 and pasted them to my root dir in my mac, the image resizes with no errors.
Also, I noticed that on my mac the cache_images folder is not created. Furthermore; the error above is stating that my folder is protected and is not because it works when I used the files created in CS4. Also the time on my 3 month mac is with the correct time.
I notice that in cs5 the CacheResize_Image file has 421 lines but in cs4 it has 485 lines.
the error is saying that the permisions are not allowing folders to be crteated in the image_cache folder by the script.
In dreamweaver, set the files panel to Testing Server view, then right click the image_cache folder and select Set Permisions.
set the permissions to allow Read Write Access for the Owner , User / Group and Evewrybody users.
the second error is saying that the timezone is not set correctly in the PHP.ini file.
you need to set the date.timezone setting in the php.ini.
see the following for a list of excepted timezones:
timezones.php
danny405167
Is the cache_images folder created automatically by Imagerisizer or I am suppose to create it? In my mac the cache_images folder is not created. When I create the folder it has permission for read and write. In fact all of my folders have a permission for read and write.
I never had to do the this step on my PC "In dreamweaver, set the files panel to Testing Server view, then right click the image_cache folder and select Set Permisions". Is if just for macs?
The following error: "the second error is saying that the timezone is not set correctly in the PHP.ini file". This is confusing because if my time zone was incorrectly, then my files created by Imageresizer in a pc with cs4 should not worked but they do.
Last question, why does the CachedResize_Image has more line codes in cs4 then cs5. Is it because different os and cs version?
For the most part, that folder should get created automatically, if it does not get created automatically, then you will need to create it manually.
it's not so much a mac versus pc issue. The problem is that the code is trying to create the folder, but it does not have sufficient permissions to do so.
are you testing the files you create with the pc on the same testing server as the files you create with the mac?
I can only tell what the error message means. It is a php configuration issue.
For the size difference, it could be that you have the 1.01 beta version installed on the PC and the 1.00 release version installed on the mac
danny405167
This is what I have
At work I have a DELL with WINDOWS 7 Pro, CS4 and Imageresizer 1.0.0. The php server is PHP Version 5.2.12 and APACHE 2.2.
At home MAC i3 with SNOW LEOPARD, CS5 and Imageresizer 1.0.0. The php server is 5 something and I think I am runing APACHE 2.2.
so you are using 2 diferent testing servers, on one testing server the php.ini file is set correctly, on the other testing server the php.ini file is not.
