Email leaving out one field
Thread begun 10/07/2010 8:34 am by julie383376 | Last modified 10/07/2010 12:49 pm by Jason Byrnes | 1996 views | 3 replies |
julie383376
I created a custom email reply and used the bindings panel to drag/drop the form elements into the message.
All my fields are showing but one, and it's a list - everything else is either a text box or radio group.
In the form, the select id is "Quote_group_Number_of_Tires"
The Labels are: Single Tire, 2 Tires, 3 Tires, etc.
The Values are: Single Tire, 2 Tires, 3 Tires, etc.
In my email, the line where I put this field says:
<?php echo ((isset($_POST["Quote_group_Number_of_Tires[]"]))?$_POST["Quote_group_Number_of_Tires[]"]:"")?>
Is there something special I should do to make the list choice show? Or do you need more info...?
Thanks!
~Julie
when dealing with a multiple select list, the selected options are added to an array. You need to use the implode function to convert the array to a comma separated list:
<?php echo ((isset($_POST["Quote_group_Number_of_Tires"]))?implode(", ",$_POST["Quote_group_Number_of_Tires"]):"")?>
julie383376
YAY! Thank you :)
you're welcome.
