Word Wrapping in Css Menu writer
Thread begun 10/06/2010 9:30 pm by larry268887 | Last modified 10/07/2010 11:44 am by Jason Byrnes | 3463 views | 3 replies |
larry268887
I want to convert a pop menu magic menu to a css menu writer menu. This should be simple except I need to be able to word wrap like the pop menu magic menu.
The new menu is a vertical menu and the category will be bevel.
Can I word wrap with CSS menu writer and if so how?
Larry
In the menu.css file, you can remove white-space: nowrap; attribute from the li element to allow for word wrap. For example:
ul#cssmw0 li {
background-image: none;
float: left;
padding: 0 0 0 0;
position: relative;
/*white-space: nowrap;*/
z-index: 100;
larry268887
Thanks, worked like a charm.
you're welcome.
