Currency
Thread begun 9/29/2010 11:23 pm by Endrio | Last modified 10/05/2010 5:44 am by Ray Borduin | 3202 views | 8 replies |
Endrio
Currency
there is a procedure to change the currency in PS4, as in PS3?
MikeH
I think its a complete DIY solution. Biggist pro/con this time is its mainly in the includes so not quite as straightforward to track down the currency. Plus side is that you only should need to change them once and it should be ok for all skins as they use the includes.
The worst is finding all the changes inside the charts and any JS currency.
I still stand by my original thoughts as of PS3 at the very least there should have been several download versions of PS in different currencies. The programmers will not a lot easier where all these changes should be made and surely wouldn't take too long to convert for us.
Anyway, I will attempt it as soon as I find the time just a pity its not easy for all customers.
I think WA doa fine job with their extensions but massivly fail with PS non-us support.
Mike
Mike
esmsBeta Tester
It's to be included in PS5.
showthread.php?t=16174
Incidentally, you can buy PS4 with sterling not just dollars so it mustn't be too big a job, I assume - but beyond me admittedly - to write something that allows the currency to change to the Queen's money!
Endrio
I may have worded my question wrong,
I can change the dollar symbol with euro symbol?
Read: showthread.php?t=16226
I give a few tips on updating currency symbols there.
Endrio
means that if I search with dreawaver in the root :
$#val#
and replace instances with:
€#val#
change the symbol dollar with Euro?
That will replace it in the charts. There are a couple of other search strings recommended in that thread to find all of the symbol references to replace.
Endrio
Can could you give an example of how to search the simbol?
Could it be better instead of the dollar sign, write USD?
would have been easier to find.
Examples of what to search for are covered in:
