A bit of help here
Thread begun 9/27/2010 3:49 pm by vze2btvh415445 | Last modified 9/28/2010 7:04 am by Jason Byrnes | 1539 views | 1 replies |
vze2btvh415445
A bit of help here
I purchased the contact form solutions pack. You need to bear with me as I work all day coding and I need to use this so I can add a contact form to an already designed html page in Dreamweaver CS5.
I need to insert the form inside a div tag I already have css for, your instructions explain how to incorporate this into a .dwt which does me no good.
I would have thought this would come with standard html file which you would be able to copy the contents into an existing or a css solution as well. So I guess I have to start from scratch. Do I need any other DW extensions for this?
I hope not.
Can someone give me instructions like I was a newbie on how to do this?
there are three code blocks on the contact page you will need to copy and past into your existing page.
From line 1 until the doctype tag is all of the server side code needed to perform validation and send the email. Copy this code and paste it above the doctype tag on your page.
Then there is the form.
copy from <form.. to the closing </form> tag and paste this into the body of your page.
newar the bottom of the apge is the spry script code:
var sprytextfield1 = new Spry.Widget.ValidationTextField("sprytextfield1", "none", {validateOn:["blur"]});
var sprytextfield2 = new Spry.Widget.ValidationTextField("sprytextfield2", "email", {validateOn:["blur"]});
var sprytextarea1 = new Spry.Widget.ValidationTextarea("sprytextarea1", {validateOn:["blur"]});
var sprytextfield3 = new Spry.Widget.ValidationTextField("sprytextfield3", "none", {validateOn:["blur"], minChars:<?php echo $WAGLOBAL_Captcha_Characters; ?>, maxChars:<?php echo $WAGLOBAL_Captcha_Characters; ?>});
var sprytextfield4 = new Spry.Widget.ValidationTextField("sprytextfield4", "none", {validateOn:["blur"]});
</script>
copy this and paste into your page just before the closing </body> tag.
