Exceeded Paypal button limited at 100 using Expression WEB 4.
Thread begun 9/27/2010 3:10 pm by sale415371 | Last modified 8/30/2011 10:44 am by connorpower429193 | 9470 views | 9 replies |
sale415371
HI
I have an issue with paypal buttom the amount. I m using expression web 4. it said i have exceeded the max paypal button for paypal can retrieved. is there anyway i can extend the amount?.. i need about 1000 + items. can someone help me please
please post the exact error message co i can investigate.
sale415371
the error message said. "you have exceeded the maximum number of button that payment button for paypal can retrieve." that is the error message.
Dani Chankhour
Yes. PayPal have a limitation on the number of buttons it returns. If you have more than a 100+ buttons, then PayPal won't return any buttons.
In Future dot releases we are going to address this issue by adjusting the dates to only return Buttons between certain dates.
dot.rust427332
We received the same message (Dreamweaver extension). So what is the solution? Are we limited to 100 buttons or do we just delete the old PayPal buttons and start over?
Dani Chankhour
Unfortunately, there is no good work around this issue, however, if you are not using your old buttons then you can delete them, and as long as you have less than a 100 buttons then the buttons will get populated and you are able to use them.
The issue is a limitation to the PayPal API which only returns the first 100 buttons.
dot.rust427332
next iteration?
So is there a new version out now or coming soon that will allow us to specify a time frame for the api calls?
Paypal needs to address this in the API.
the API itself is where the limitation is.
We will not be able to fix this till PayPal fixes the API.
dot.rust427332
but...
Originally Said By: Dani Chankhour
When I spoke with PayPal, they did confirm that they only return 100 buttons *at a time*, but we could get another 100 buttons, then another, if we adjusted the time frame by increments. I guess my question is will you be doing what Dani said above and give us a way to adjust the time frame?
connorpower429193
Update?
Has there been any update to this issue?
