Editing recordsets
Thread begun 9/26/2010 4:12 pm by nickj | Last modified 9/27/2010 12:05 pm by Jason Byrnes | 1969 views | 3 replies |
nickj
Editing recordsets
I have an update page which I need to alter the recordset, I need to add additional filter which I do, then save then upload and everything is great.
But when I go back to that page in DW and open the resordset it reverts the query to the old one without the additional filters, and something writes a new recordset with the same name!
How should I update the recordset created by DataAssist?
Nick
CraigRBeta Tester
This seems very strange.
If you try and edit a recordset via the Dreamweaver recordset bindings interface, I find that dreamweaver often duplicates the recordset, so you get 2 recordsets with the same name.
Have you tried editing the recordset manually in the code window, without opening up the bindings interface ?
nickj
Yes, and that works fine for adding ot he select statement but the the WA/DW has a very specific method of writing the the where statement when filtering by Session, Get or Post. Often I like to open the recordset via the pallet the copy the query to work with in a query editor.
Just opening the recordset breaks it!
Nick
can you send a copy of your page so I can examine the code to see if there is something there that may be causing the issue.
