Error Messages
I have corrected the path to /home/username/php/ and now I don't get an error. But still the person who fills out the form does not get my email sent to them. It is supposed to send out an email to them? Correct. I get their message but they do not get one. What am I not doing. In both Mail and Pear, the email is not received. Am I to attached the message or do any further steps?
Let me confirm, From and To on Create Email Message is to have my email address. Correct? To is not the person who clicks the submit button, correct?
Thank you.
Serge
Discussed path to pear with hosting provider he gave me “/username/php/”, I need to included the “/” at the end. But I still get errors messages:
Patch was installed.
So I looked at the server php directory under Mail.php and when I tried to view it it indicated the following: The file Mail.php cannot be opened: The asociated program (WX_DDE# “C:\ProgramFiles\Adobe\AdobeDreamweaverCS4\Dreamweaver.exe”,”Mail.php”##System#) could not be found. Please check your file type associations.
Then I saw that there was a subdirectory under php called Mail and in it had mail.php file so I modified the path to /username/php/Mail/ but I still got errors then I modified the line 113 of PEAR_Mail_using_SMTP_php.php to be mail.php instead of Mail.php. But still I get errors.
Errors:
Warning: require_once(/username/php/Mail.php) [function.require-once]: failed to open stream: No such file or directory in /home/ username/public_html/ChickenTwentyFive/webassist/email/PEAR_Mail_using_SMTP_php.php on line 113
Fatal error: require_once() [function.require]: Failed opening required '/ username/php/Mail.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/home/ username/php') in /home/username/public_html/ChickenTwentyFive/webassist/email/PEAR_Mail_using_SMTP_php.php on line 113
These same warning statements as above occured if with path to pear being:
(/spibr/php/Mail/Mail.php)
(/spibr/php/Mail/mail.php)
Thanks for your help. Help.
Serge
