using more than 1 javascript library
Thread begun 6/11/2009 6:08 am by CraigR | Last modified 6/28/2009 10:02 am by CraigR | 9587 views | 10 replies |
CraigRBeta Tester
i am playing with various javascript tools, such as slideshows and carousels and which invariably use different libraries, such as mootols, jquery and yui.
I presume it's not a particularly good idea to mix & match, but wonder if its possible to use 2 different libraries on the same page.
I'm currently developing my site, and have a header which is based on slideshow 2, (mootools) which loops through a series of still images to give me (imho) a nice effect.
www.stonepits.com
I am currently looking at javascript carousels, ideally for one where i can have text and images, which provide links to external content.
After playing with jcarousel for a couple of days, i think the yui carousel is more powerful, and have got something working, (not finished, but working)
The problem is that i cant get both to work on the same page.
yuicarousel.php
Is it a case of loading the libraries in the correct order, or is the problem more fuindamental ?
If i am hitting a wall, can someone please recommend a good yui based tool to act like slideshow ?
regards
Justin Nemeth
It really depends on how the framework is implemented. Most javascript frameworks extend the built in JavaScript functions, so that is why you are likely getting conflicts. For instance, many frameworks have a $() function to get a quick reference, but if mootools and yui have that, it will cause errors since both are trying to declare the function and presumably doing it separate ways.
So, my general recommendation would be to stick with a single framework since that will always work.
I don't have any recommendtions for a yui slideshow since I primarily use mootools myself. Hopefully someone else has more experience there.
CraigRBeta Tester
Thanks Justin.
Just to confuse matters more, i noticed that with both js libraries, IE7 works fine, (!), but in FF the carousel will not work.
Removing the mootools libraries from the page and the carousel is fine.
Justin Nemeth
I would recommend installing Firebug for Firefox, its a free add-on. You can them see what javascript errors are occurring. I am not sure why it would work in IE7 and not in FF, but Firebug should help you track it down.
CraigRBeta Tester
error
i ran firebug and got the following error.
can you help me decipher it ?
uncaught exception: [Exception... "Component returned failure code: 0x80004003 (NS_ERROR_INVALID_POINTER) [nsIDOMHTMLDivElement.insertBefore]" nsresult: "0x80004003 (NS_ERROR_INVALID_POINTER)" location: "JS frame :: element-min.js :: anonymous :: line 7" data: no]
Further to the above, I found a nice little javascript 'conveyor belt' which is really nice and simple, and gives me another option.
It populates the scrolling element by means of a javascript array.
I have linked my test page to a recordset and can use this recordset to populate a javascript array using php.
conveyorbelt.php
Justin Nemeth
Not really sure about that error, but it seems to point to the inner workings of the YUI files. You could double check you have the most recent YUI files, but beyond that you probably have to look around to see if anyone else has encountered a similar error.
CraigRBeta Tester
never mind
Thanks for your help.
I think i'll stick with my simple alternative for now until I get a bit more experience of other tools.
CraigRBeta Tester
loading issue
i created a page with a newsticker and an image conveyor, and on my local server everything is fine.
when published to my isp, the page (usually) only loads the news ticker, until I refresh the page when the whole page loads.
newsticker.php
CraigRBeta Tester
sorted.
never mind, problem resolved.
Justin Nemeth
Hey Craig, I noticed this post over on the mootools blog. They have implemented a 'dollar safe mode' that should help cut down the conflicts with other frameworks. I still would recommend sticking to one framework, but this update might help if you have to use 2.
the-dollar-safe-mode/
