Check box value not transferring
Thread begun 9/21/2010 11:00 am by Badger | Last modified 4/12/2011 8:44 am by Jason Byrnes | 3971 views | 7 replies |
Badger
Hi. I have a lovely WAFB form being emailed using WAUE. Everything being emailed except three check box values.
I used the bindings panel to add the values to the UE page and they all work except the check boxes.
In the UI for editing the check boxes (called CSS Form Builder - List Values):
I've got 3 different "Item label" the same as 3 "Value" as that's what I want emailed. Should this be a numeric or other value?. There is no validation required (and it's not ticked).
The only other thing I can see that might causing the values not to be emailed is the Legend and Title are used in the form field "name" and "id" which in this case is over 80 characters. If that is too long, should I enter a shorter value in the CSS Form Builder edit and hand code something afterwards.
Or something else is the issue?
BTW, my help button won't open any help files in Google Chrome. Any ideas?
B
please send a copy of your page so I can take a look at the code.
Badger
Thanks Janson
OK, so its a multi checkbox.
with a multi checkbox, can you send the webassist/email folder so i can see how the message is coded.
Badger
here it is...
when working with a multiple checkbox, the selected items are added to an array.
you need to use the implode(); function to convert the array to a comma separated list.
in the code to display the checkbox values, you have:
$MailBody = $MailBody .  ((isset($_POST["Other_services_group_Enquire_about_our_other_Chandelier_Group_services_tick_box_to_select[]"]))?$_POST["Other_services_group_Enquire_about_our_other_Chandelier_Group_services_tick_box_to_select[]"]:"");
this needs to be changed to:
$MailBody = $MailBody .  ((isset($_POST["Other_services_group_Enquire_about_our_other_Chandelier_Group_services_tick_box_to_select"]))?implode(", ",$_POST["Other_services_group_Enquire_about_our_other_Chandelier_Group_services_tick_box_to_select"]):"");
Badger
using:
implode(", ",$_POST["Other_services_group_Enquire_about_our_other_Chandelier_Group_services_tick_box_to_select"):"");
Giver the error message:
Parse error: syntax error, unexpected ')', expecting ']' in /www/visp/hollywo1/chandeliergroup.com/webassist/email/waue_Items_Detail_4.php on line 91
try this then:
