PowerStore 4 Build 023
Thread begun 9/20/2010 8:10 pm by Anna Robinson | Last modified 9/23/2010 2:57 am by John Langer | 4001 views | 12 replies |
Anna Robinson
PowerStore 4 Build 023 is now available.
Download build.
serial #: hPOHS-YRBMc-0yAiM-FojLQ
Nearly all bugs are fixed at this time so please report anything and everything you find that seems to be a bug. We are getting close to QA sign-off and the beta will likely be closed in a day or two.
Thanks to everyone that has been participating.
anonymous
Theme Selection Quit Working
I had one theme selected and went in to edit one that was not currently selected.
After editing, it became my theme. But then, I have not been able to select any of the other themes.
anonymous
Update on that last issue: it seems to be a problem with caching. Once I deleted my browser cache, I was able to select again.
anonymous
OK... there does seem to be an issue that when I try to edit a template, it brings in a pop up with the inline style editor - but the admin page in background tried to go to the "unload.php" and then it throws an internal server error 500.
Anna Robinson
I've reported to QA; we will work to reproduce. Thank you.
CraigRBeta Tester
problem i reported in build 18 is still there in 23
Anna Robinson
Hmmm. Maybe due to not a clean install? Either way, I'll bring it to QA's attention. Thanks!
Matthew Meling
Hey Sojo,
We've been unable to track down exactly what happened to you. Could you please give us more details about the steps you took to make this happen?
Matthew Meling
Hey Craig,
The issue you had sneaked back in, but we will definitely not let it sneak in again.
Thanks for making us aware
anonymous
Originally Said By: Matthew Meling
  Hey Sojo,
Matthew,
The issue I am getting may also be because while I am on a live production server, I am not using my actual domain (as I am transferring the domain to a new host). So I am using the server name in combination with my username to view the site - so it could be creating an issue with resolving the domain correctly.
I am hoping to have that domain on the new server and then I will test again. If I have the problem again, I will let you know or we can get online and I will show you as it happens.
Thanks,
Brian
