DIV added/renamed...etc !!!!
Thread began 9/15/2010 1:06 am by Cologne | Last modified 9/15/2010 11:08 am by Jason Byrnes | 1203 views | 3 replies |
Cologne
whats wrong with Sculptor? When I add new DIVs I cant rename them or set width height etc.
I always have to start NEW!
OK, I installed the latest version 3.02...but I still cant rename the divs, it always sets the 2 at my new name :-( where can I change this by hand or something ?
Denis
I am not able to reproduce the issue. I can rename the div after inserting it. You need to select another element for the new name to take.
Are you using one of the standard presets, or a saved preset?
if a saved preset, please export it and attach the saved preset so I can try using the same preset.
Cologne
ok, here we go...
when I work on the CSS in the DW CSS panel, there are DIV23 DIV124 or something.
cheers
Denis
layoutStandard.zip
Hmmm, yes, I can reproduce the issue using your layout.
