moving store files to root
Thread begun 9/11/2010 12:45 am by rmountain411063 | Last modified 9/13/2010 10:59 am by Jason Byrnes | 2749 views | 4 replies |
rmountain411063
In moving the store files to the root of the website I'm now being directed to the installation process when I go to the root web address. The files have been uploaded to an external host where I've already started the database and added content and product.
I've gone into the 'wa_settings' in the data base and removed the references to the original folder where the files were located. In the 'wa_settings', the 'root URL' now reads mywebsite.com
Is there a step by step or checklist of things that I can use to find a solution to this problem?
thanks,
Rod M.
siteontimeBeta Tester
The easiest fix for this if everything was working properly before you moved the files would be to remove the first 10 lines of code in the WA_Globals.php file.
Delete these lines:
//need to run installation wizard
if(!file_exists('../Connections/installed.txt') && (!file_exists('Connections/installed.txt'))) {
if(file_exists('../install/index.php')) {
header('Location: ../install/index.php');
} else {
header('Location: install/index.php');
exit();
Make sure you don't leave a blank line in the page. This code is looking for the installed.txt file in the connections folder and if it doesn't find it, it starts the install process.
I hope that helps.
rmountain411063
Uploading to live server, empty delimiter error msg
Thanks Jennifer,
As my first attempt, I'm not sure what kind of mess I've made for myself here. My images and CSS is not showing up properly (or at all), getting 404 msg and 'empty delimiter' error msgs. My goal to fix this and use the SQL database that I've built up already.
I'd like to understand how to trouble shoot these problems I have now and also build a checklist of sorts for future use.
I'm looking forward to any feedback and addons to the list from experienced users.
Moving PowerStore 3 files to live server (root folder)
1. Delete these lines from the WA_Globals.php file
} else {
exit();
2. Update SQL Database 'wa_settings' file line 1 (Root URL) to reflect the root folder of the websiste as 'http://www.mywebsite.com' and NOT 'http://www.mywebsite.com/PowerStore300'.
Delete '/PowerStore30/' from line 9 (Local Root) and 10 (Remote Root).
eg. mywebsite.com NOT PowerStore300
3. From inside Dreamweaver; Move the website files from the 'PowerStore300' folder to the root.
4. Update any references inside the index.php file so that it is not looking for the 'PowerStore300' folder.
5. Upload the files to the live server (root folder).
Include 'Connections' folder? What file(s) should be inside the connections folder?
6. Remove any previous website files such as index.html, CSS files, and 'PowerStore300' folder from the live server.
7. Log into WebAssist Admin and update details for going live.
rmountain411063
empty delimiter errors
I'll post the code here as the images above are too small
empty delimiter error from line 6: if (strpos(strtolower($WA_thisFile), strtolower($assumedRoot)) === 0) {
and line 10: if (strpos(strtolower($WA_thisFile), strtolower($assumedRoot)) === 0) {
$WA_localRoot = "" .$WAGLOBAL_localRoot ."";
$WA_remoteRoot = "" .$WAGLOBAL_remoteRoot. "";
$WA_curURL = strtolower((isset($_SERVER["PHP_SELF"]))?$_SERVER["PHP_SELF"]:"");
$assumedRoot = $WA_remoteRoot;
if (strpos($WA_curURL,strtolower($WA_localRoot)) === 0 && (strlen($WA_localRoot) >= strlen($WA_remoteRoot) || strpos($WA_curURL,strtolower($WA_localRoot)) === 0)) {
$assumedRoot = $WA_localRoot;
$WA_thisFile = $_SERVER['PHP_SELF'];
$WA_thisFile = substr($WA_thisFile, strlen($assumedRoot));
else {
$WA_thisFile = substr($WA_thisFile, 1);
$WA_ddsArray = explode("/", $WA_thisFile);
$WA_dotDotSlash = "";
for ($n=0; $n<sizeof($WA_ddsArray)-1; $n++) {
$WA_dotDotSlash .= "../";
?><?php
// MenuWriter connection includes
require_once($WA_dotDotSlash . "Connections/PowerStoreConnection.php");
// end connection includes
// MenuWriter ignore connection includes
if (1 == 0) {
?><?php require_once('../../Connections/PowerStoreConnection.php'); ?><?php } // End MenuWriter ignore connection includes ?>
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
function recursiveNesting($catID) {
$retVal = "";
mysql_select_db($GLOBALS['database_PowerStoreConnection'], $GLOBALS['PowerStoreConnection']);
$query_menuwriter_categories1 = sprintf("SELECT CategoryName, CategoryID, CategoryParent FROM ps3_categories WHERE CategoryParent=%s", GetSQLValueString($catID, "int"));
$menuwriter_categories1 = mysql_query($query_menuwriter_categories1, $GLOBALS['PowerStoreConnection']) or die(mysql_error());
$row_menuwriter_categories1 = mysql_fetch_assoc($menuwriter_categories1);
$totalRows_menuwriter_categories1 = mysql_num_rows($menuwriter_categories1);
if ($totalRows_menuwriter_categories1 > 0) {
$retVal .= '<ul class="level-2">';
do {
$retVal .= ' <li><a href="'.($GLOBALS['assumedRoot']).'Products_Results.php?Search=1&ProductCategoryID[]='.$row_menuwriter_categories1["CategoryID"].'">'.$row_menuwriter_categories1["CategoryName"].'</a>';
$retVal .= recursiveNesting($row_menuwriter_categories1["CategoryID"]) . '</li>';
} while ($row_menuwriter_categories1 = mysql_fetch_assoc($menuwriter_categories1));
$retVal .= '</ul>';
mysql_free_result($menuwriter_categories1);
return $retVal;
<ul class="level-0" id="cssmw_home">
<li><span><a href="<?php echo($assumedRoot); ?>index.php">Home</a></span></li>
<li class="parent"><span><a href="<?php echo($assumedRoot); ?>Products_Results.php">Products</a></span>
mysql_select_db($database_PowerStoreConnection, $PowerStoreConnection);
$query_menuwriter_categories = "SELECT CategoryName, CategoryID FROM ps3_categories WHERE CategoryParent = 0";
$menuwriter_categories = mysql_query($query_menuwriter_categories, $PowerStoreConnection) or die(mysql_error());
$row_menuwriter_categories = mysql_fetch_assoc($menuwriter_categories);
$totalRows_menuwriter_categories = mysql_num_rows($menuwriter_categories);
<ul class="level-1">
<li><a href="<?php echo($assumedRoot); ?>Products_Search.php">Search</a></li>
<li><a href="<?php echo($assumedRoot); ?>Products_Results.php?Search=0">Show All Products</a></li>
<?php if ($totalRows_menuwriter_categories > 0) { // Show if recordset not empty ?>
<?php do { ?>
<li class="parent"><a href="<?php echo($assumedRoot); ?>Products_Results.php?Search=1&ProductCategoryID[]=<?php echo $row_menuwriter_categories["CategoryID"]; ?>"><?php echo $row_menuwriter_categories["CategoryName"]; ?></a>
<?php echo(recursiveNesting($row_menuwriter_categories["CategoryID"])) ?>
</li>
<?php } while ($row_menuwriter_categories = mysql_fetch_assoc($menuwriter_categories)); ?>
<?php } // Show if recordset not empty ?>
</ul>
mysql_free_result($menuwriter_categories);
</li>
<li class="parent"><span><a href="<?php echo($assumedRoot); ?>Support.php">Support</a></span>
<li><a href="<?php echo($assumedRoot); ?>Ordering.php">Ordering</a></li>
<li><a href="<?php echo($assumedRoot); ?>Shipping.php">Shipping</a></li>
<li><a href="<?php echo($assumedRoot); ?>Returns.php">Returns</a></li>
<li><a href="<?php echo($assumedRoot); ?>orders_History.php">Order History</a></li>
</ul>
</li>
<li><span><a href="<?php echo($assumedRoot); ?>AboutUs.php">About Us</a></span></li>
<li><span><a href="<?php echo($assumedRoot); ?>contactus.php">Contact Us</a></span></li>
</ul>
<script type="text/javascript">if(window.attachEvent) { window.attachEvent("onload", function() { cssmw_home.intializeMenu('cssmw_home',{select_current: 1, orientation: 1}); }); } else if(window.addEventListener) { window.addEventListener("load", function() { cssmw_home.intializeMenu('cssmw_home',{select_current: 1, orientation: 1}); }, true); }</script>
error also on line 134 from the index.php file
if ((strpos($WA_curURL,strtolower($WA_localRoot)) !== false && strpos($WA_curURL,strtolower($WA_localRoot)) == 0) && (strlen($WA_localRoot) >= strlen($WA_remoteRoot) || strpos($WA_curURL,strtolower($WA_localRoot)) === 0)) {
In the wa settings table, make sure the root URL ends in slash:
mywebsite.com/
instead of
mywebsite.com
for the local root and remote
Also, the remote root and local root setting should be set to "/" and not left empty.
