Can't Edit an Existing Form
Thread begun 9/10/2010 7:20 pm by Jim376112 | Last modified 9/15/2010 6:44 am by Jason Byrnes | 5160 views | 13 replies |
Jim376112
Hello,
I am using Dreamweaver CS4 and have just purchased CSS Form Builder. I can create a form but I can't come back and edit it. I am following the steps in your modifying_custom_form.pdf instructions file.
To create the form I use File | New and create a new .PHP file and Save it. Then I choose Insert | ... | Insert Form and select the following:
Contact (Simple)
Cool
Action Page = the same page
POST
and I save the form.
Then, per the instructions, in Server Behaviors I delete 1 "WA Server Validations" and 4 "Show if()" entries. Then I click in the Name field of the form | Insert | ... | Insert Form and the dialog box comes up. In the Preview area it flashes "Please Wait. Generating Form" but then the Preview area turns empty. Pushing the "Choose a Form" | Edit button also brings up an empty window. I've tried this several times with the same results.
Can someone tell me what's going wrong here?
Thank you!
anonymous
Jim,
To edit an already existing form, you should be able to select the blue "bounding" box that surrounds the entire form. It will contain the name of the form. When you select it, you should then be able to see the choice in the Dreamweaver properties inspector (usually at the bottom) where you can edit the entire form (both content and appearance), edit contents, or edit just the design.
Best regards,
Brian
Jim376112
Hi Brian,
Again, thanks for responding on the weekend!
Also, thanks for revealing how to edit an existing form - your approach works. I (foolishly) "read the manual" which apparently is very wrong. The instructions in modifying_custom_form.pdf say that after selecting the form you should again select Insert | WebAssist| CSS Form Builder | Insert Form which does *not* open up to edit the existing form!
Thanks again for answering so quickly.
Jim
to clarify, the modifying_custom_form.pdf instructions is talking about a custom form, One that was initially created outside of Form Builder.
The help documentation describes the steps for reentering the Form Builder wizard:
index.htm
Go to Using CSS Form Builder -> Reentering the interface
Jim376112
Hi Brian,
Thanks for the additional clarification and thanks in particular for revealing that there is an extensive User Guide available at the link you provided (index.htm)!
How would I have found that User Guide? Upon purchase, I had originally gone to My Account | Your Account | CSS Form Builder and reviewed all available links. I just did that again and I am unable to locate a link to this (extensive) User Guide!
How would I have found this guide and, since I've purchased quite a few other extensions, how would I find similar User Guides for my other extensions. If they are as extensive as the one for CSS Form Builder they would be a "gold mine" of useful info!
Thanks again.
Jim
the help docs for each extension are available through the Help Menu in Dreamweave. Go to Help -> WebAssist
The online versions are also available on the support page for each product.
For Form builder, go to:
css-form-builder/
the help doc is linked at the top in the sentence "CSS Form Builder includes a full online help system"
the same online help link is available on each products support page
to access all support resources, start here:
support/
Jim376112
Hi Jason,
Wow, you've just "opened up" a whole new universe for me by giving me those links!
For some reason, the relationship of the pages hasn't been clear until I took those links and pieced them together with the pages I've been looking at. Now I see how to get to the "Support and Training" page for any extension I've purchased, plus I now see the link to the User Guide on that page. "Now that I understand, I understand." (Boy, that's a common one!). Not sure why I hadn't put all this together before but I'm excited to see that there is a lot more documentation for all of my extensions available than I've been aware of.
Thanks again to you and to Brian.
you're welcome.
Jim376112
Hi Jason,
Oops, one more issue. I just stepped through all of my extensions to locate the User Guide but for the following two there is no Guide (there is no link on the Support & Training page):
Power Gallery
Universal Email 4
Am I missing these at some other location or is there just no User Guide as with the others?
Thanks.
the UE help documentation can be found here:
index.htm#home.htm
the link can be found on the right side of the support page under documentation:
Documentation
Recent Updates
Built-in Help
Archived Documentation
the Solution Packs do not have the same sort of help documentation, the getting started guide walks through the installation and configuration process, that should be all that needs to be done with them.
