Transferring data base PowerStore 3 created
Thread begun 9/10/2010 12:43 pm by vecenniamjordan289639 | Last modified 9/13/2010 6:31 am by Jason Byrnes | 1083 views | 1 replies |
I went through the installation process to install Power-store 3 to my remote host. I used dream-weaver as my ftp. "Perfect" The Power-store installation setup my MySQL database I created on my remote host with all the tables and information_schema required. "Perfect" Now, I want to export the database from my remote host to import it on my pc localhost for testing in dream-weaver. "Problem"
I believe my first issue is with exporting the data base from my remote host phpMyAdmin.
I get some warning or error that looks like this...
(1 This value is interpreted using strftime, so you can use time formatting strings. Additionally the following transformations will happen: __SERVER__/ server name __DB__/ database name. Other text will be kept as is.)
I don't know what this means but when I try to import the .sql file that's created on my test
site only 3 of the data base tables is imported before it errors.
Please Help!!!
What exactly are the errors you are encountering? it's impossible to tell what may be going wrong without knowing the error text.
