create variable for Record ID and send in URL
Thread begun 9/05/2010 9:26 am by neilo | Last modified 9/06/2010 10:50 am by neilo | 6658 views | 8 replies |
neilo
As you well know, I have the ability to look at a page full of PHP code, and within just a few seconds, come up with a recipe for lemon-drizzle cake. I need help to do this simple procedure:
I have done a couple of sites that have a 'Quick Links' area which draws its content from a database (here and here)
On the page I have a recordset (calendar).
I have a repeating region containing the dynamic text drawn from the recordset, therefore I have (once the HTML is stripped out) the following, which is all OK:
<?php echo date('jS F Y',strtotime($row_calendar['event_begin'])); ?>
<?php echo date('g:ia',strtotime($row_calendar['event_time'])); ?>
<?php echo $row_calendar['event_title']; ?>
<?php echo $row_calendar['event_short']; ?>
I need to add in to the repeating region a value for event_id from the recordset (hidden) as a variable that I can carry forward in a URL to another page, so that I can do a SELECT FROM using that ID on the new page.
The simple aim is to have a 'more . . . ' link for each record in the repeating region that links to a page with full details of that particular event.
Please could someone baby-step me through this apparently simple procedure?
John LangerBeta Tester
Hi Neilo,
Jason and I answered a similar request only the other day here.
If that doesn't do it, post back. I'm actually off on holiday now for a week but I'm sure someone will pick up on it.
neilo
Hi John,
Yes - that is exactly what I needed!
Many thanks, and have a great holiday,
best,
neilo
I can't seem to get this working. Both sets of instruction given were very clear, and I'm convinced all is entered correctly.
The link is this:
<a href="eventInfo.php?id=<?php echo $row_calendar['event_id']; ?>">more . . .</a>
There is currently only one record, so the link directs correctly to the page with the query string in the URL ( eventInfo.php?id=1)
That (detail) page - eventInfo.php - has the recordset properly added, filtering by event_id (which is the unique auto-incrementing primary key) equal to 'URL', and populating the box next to it correctly with event_id. (Image: recordset.jpg)
When I press the 'Test' button (CS5) i get the message asking me to provide a test value for the URL Parameter: event_id. I enter the Test value 1 (the only record) and the test succeeds and shows me the correct data for that query. (Image: Test_SQL_Statement.jpg)
Howevr, when I click the 'more . . .' link from the home page, I get to a blank 'detail' page, with no record pulled from the database.
I hope someone may be able to throw some light on this.
Thanks.
P.S - I'm also getting an error message at the bottom of the page, if I use a template page with the 'Quick Links' include on the page:
Warning: mysql_free_result(): 17 is not a valid MySQL result resource in /home/users/uks45031/html/katelissauer.com/eventInfo.php on line 185.
(I don't know what the '17' is about)
If I create a 'detail' page from a blank .php page, I don't get that error, but I still don't get a record returned.
neilo
Doh!
I'd put 'php?id=' instead of 'php?event_id='. What an idiot.
I still have the error message at the bottom of the page, though. Can I just delete the mysql_free_result php block to make the error go away, or will that cause problems?
Am also getting a character encoding glitch, with the £ sign and apostrophes being represented by the &#65533; symbol.
You can see the effect by clicking the 'more . . . ' link in the 'Quick Links' area HERE
If anyone has any ideas about the encoding or the 'mysql_free_results' glitches, I'd appreciate your thoughts.
Dave BuchholzBeta Tester
this error
is caused by the fact there is no recordset code on the page created from the template I suspect but without seeing the actual files it is difficult to be certain
try using the html entity equivalents, there is a great list here
neilo
Hi Dave,
Thanks for the link to the 'entities' page - that is a really complete and useful resource.
I do have the recordset code on the page, though. I am thinking now that the error might be caused because the 'Quick Link' include page has a 'mysql_free_results' php block at the bottom of the page, so that when this appears at the bottom of the detail page as well, the browser reads two such blocks of code when it only needs one (i.e. it acts on one, then gets the same request again). Could that be why I get the error?
yes you only need one block of that code
neilo
Thanks Dave,
I have removed the duplicate, and all works well.
